Community Forum Actions
Results 1 to 10 of 10
Thread: ALTO Gear Shift becoming Hard!
    uetian04's Avatar
    Aug 2011
    146
    4 Post(s)
    Question ALTO Gear Shift becoming Hard!
    Dear All;
    From last few weeks, I'm feeling that my ALTO VXR (2006,38K) gear shift going to be hard. More force is needed to shift gear than before. Many time reverse gear produce sound while shifting.
    Can some body help me what would be the problem in gear box or other way? Do I need to flush gear oil some OR thing else need to be done?
    Regards;
    !! DIY in a professional WAY!!
    abidoon's Avatar
    May 2009
    25
    2 Post(s)
    Default Alto Gears
    Did you the buy the car second hand or was it new?
    uetian04's Avatar
    Aug 2011
    146
    4 Post(s)
    Quote Originally Posted by abidoon View Post
    I bought 2nd hand about 9 month ago.
    ekdrifter's Avatar
    May 2009
    Peshawar
    24
    8,412
    28 Post(s)
    2 Thread(s)
    well check the rod of reverse shift if its bent straighten it up will solve this problem
    else it can be simple like adjusting the clutch as the milage u say it can be true for an 06 but it could be a clean 06
    I hate myself more than I hate others. I'm miserly egoistic even with hate
    uetian04's Avatar
    Aug 2011
    146
    4 Post(s)
    Quote Originally Posted by ekdrifter View Post
    thanks for replied.
    Yes, neat & clean. remained in view before I have! Even stock tyres.
    btw, do i need to change gear oil also or just clutch adjustment?
    ekdrifter's Avatar
    May 2009
    Peshawar
    24
    8,412
    28 Post(s)
    2 Thread(s)
    Quote Originally Posted by uetian04 View Post
    thanks for replied.
    for the millage no need to change it as it needs to be changed at 80K
    it could be un adjusted clutch only
    uetian04's Avatar
    Aug 2011
    146
    4 Post(s)
    I do remembered that some time ago, I loosened the clutch nut (with clutch wire) some turns under engine body because of little late clutch engagement feeling. At that time, I did not feel notable hardness.
    Now as the case is not same, so I'll visit for clutch adjustment
    Only mileage determined gear oil change interval? Like mine have 6 year old but with 38K!
    6Forward's Avatar
    Feb 2012
    193
    check the clutch system, pedal heights and free play. Change the transmission oil and use ZIC FF
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    481
    Please don't forget to share if your problem is soloved.
    Tabish1's Avatar
    Feb 2007
    2,305
    3 Post(s)
    when I bought Alto , I feel that gear is hard , check gear oil level at oil shop , he told me that oil level is low... He filled oil , and shifting is ok alhamdulilah,,
    Pakistan <3
Similar Threads
  1. Gear Shift Lever
    By qasimdada in forum Engine / Transmission / Powertrain
    Last Post: 30-07-2009, 08:52 AM
  2. abt automatic gear shift on cng
    By ali980 in forum Engine / Transmission / Powertrain
    Last Post: 29-03-2009, 08:49 PM
  3. abt automatic gear shift on cng
    By ali980 in forum Recycle Bin
    Last Post: 28-03-2009, 10:10 PM
  4. Alto Clutch / Gear shift problem
    By mimrans in forum News / Articles / Driver Education / Safety
    Last Post: 06-11-2007, 01:32 PM
  5. What is perfect gear shift?
    By tech_wizi in forum Vehicles / Bikes
    Last Post: 26-12-2004, 01:19 PM
Tags for this Thread
