Can anybody tell me where in karachi do i find any mechanic or garage who can diagnose problems and repair Mercedes Sprinter Van ECUs ......
KARACHI RULES, KARACHI ROCK, KARACHI SLAM, KARACHI LIVE, KARACHI DREAMS, KARACHI SOUL, KARACHI HEART, KARACHI SUPPORTS. KARACHI IS PAKISTAN....
MB dealers - aka Shahnawaz Ltd can do it, private mechanics who have an MB compatible scanner can do it too, Your post is quite vague, do you have these vans or just the ECUs?
ZRS - Zulfiqar Racing Systems ..... PROFESSIONALS at WORK at CRACKWHEELS.COM
@Xulfiqar ..... Have sent my van to Shahnawaz Motor but no good ....... its not starting (EBD) Light in dash is glowing when ignition switch turns on ......
@ Capsat.. i just want my van to start ..... no mechanical issues i am 100% sure for that .. its some ECU Problem ....
Generally EBD is related to car brakes is there any brake job you got done lately by some LOCAL USTAAD ?? carefully speaking there may be Injector pump failure as well reason for failure to start.
what was findings of Shahnawaz did they gave you any print out of problems & estimate for rectification. they must have given DOSE of Gold to gulp which you must've declined and pulled vehicle out from their clutches.
- GURU Xulifiqar may guide you to a Electrical Fuse replacement to resolve the problem) no wonder
Please read --> http://www.pakwheels.com/forums/site-feedback-suggestions/181978-attention-mods
EBD is brake distribution, its joined with the BAS and ESP modules (If equipped) which do not prevent startup. The only item that prevents startup is the DAS (Drive Authorization System) if equipped - however the dash should flash start error on this fault. or no signal from the engine position sensors or extremely low fuel rail pressure. Call them up and ask for a log prinout of the faults they found. There is a relay box that can show up such elusive faults, mostly it causes the ABS pump to work overtime and the brake system warnings remain on. On a W210 and similar era road cars its called K40 relay module.
If your vehicle electronically turns on and if mechanically the engine can push out at a minimum 300 psi compression, and the fuel rail holds at least 4700 psi pressure, your cam and crank are giving correct time signals and you have good fuel - the engine will fire, otherwise check the injectors. they maybe clogged or bad. The only way to test them is with a MB diag tool or a test bench that can run them.
The ECUs themselves are not the garden variety ECU that you can find anywhere and neither can they go bad on their own they are pretty well protected electronically.
Bookmarks
