Hello everyone, I swapped a GA15DE in my 1987 Nissan B12 Chassis. It has been over a year now, the engine was running fine without problems until now.
Following are the problems that i am facing:
1: I feel that the engine has lost it's power, what could be the main reason behind that? Could it be a clutch plate issue or an electrical problem ?
2: The gear ratios are short. Is this normal ? I Usually change to the 5th gear somewhere around 80-90 K mph
3: One of the axel has been welded because i could not find an exact fit. What can be done to get rid of the weld? any possible solution?
I would like to ask all experts to give their opinions and help me out. Thanks.
3Likes
.. I will get the throttle body serviced and all the sensors checked and clean and then report.
Bookmarks
