I did not knew about many leafs. Told him to give best one he gave the one with 15 leaves cost 150 PKR.
I would remove plugs so its easy to rotate. Then I will rotate using power steering pump.
Question 1. Should i rotate TDC marks Clock Wise?
Question 2. As @syncview described the timing i googled and according to them it is
intake: 0,26 mm +- 0,02 mm
exhaust: 0,30 mm +- 0,02 mm
For Intake I will use One 0.20 and One 0.05 mm combined to produce 0.25
For Exhaust I have 0.30 mm leaf and i will use it.
Question 3. Once you adjust the screw how much tight you have to do it?
