carefully speaking 2 ton jack stand will cost not over 3000 for a pair. plus you can exercise more caution by not removing the wheels even when car is jacked up. make sure your garage floor is not squeeky clean use rubber mat under the jack for firm staying on ground.
at 1st glance the culprit seems to be Axle seal,
