how was it washed? if it washed at a service station on a lift then water can get into engine compartmenet from below, if you simply washed it yourself without opening bonnet then it shouldn't leak at all, to confirm drive in rain and then check if its wet there, if so change the sealing rubber strips on the side of the bonnet.
