Distributor position has less to do with what I had in mind.
TDC primarily concerns aligning the cam to the correct position of the first cylinder firing position.
People make mistakes of aligning with the exhaust stroke rather than the power stroke.
Once that is in 100% order, THEN and only then we use the timing gun to go about the distributor.
