Here is a note I got from Internet about
LSD Gearbox for all the newbies.
The limited slip differential powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheelspin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance).
The lsd, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel. Power to the ground!
The lsd powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheelspin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance). The lsd, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel.
In drag-race style, straight-line acceleration runs, this results in a close to ideal 50/50 power split to both drive wheels, resulting in essentially twice the grip of an ordinary differential.
The lsd biases power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed.
LSD also controls loss of traction when the front wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. The lsd provides continuous and infinitely variable drive.
Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs.
In easy words when you "rip your car " its like short shift . the gear would change when the engine produces maximum torque/hp but " with proper differentials .
the car wouldnt actually get out of control the engine would send power to exactly which tire needs more grip easy as that instead one doesnt have..
its like a drift masters dream
