Up for sale is another JDM f20b with short ratio T2T4 LSD transmission. This one is also freshly arrived and never been used in Pakistan. I have sold one before at very reasonable price and hoping to sell this one in same price bracket. It's a complete swap ready motor with all sensors, uncut wiring, ecu, cut axles etc.
wiki specs:
F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart. The F20B manual version also utilized stronger cams, intake and throttle body from the H22 type S. The difference between f20b manual (200 hp) and auto (180 hp) is cams, intake, throttle body and the gearbox for manual come with t2t4.
Specifications
- Accord SiR wagon, SiR-T F20B 97-01 2.0 L
- Valve train: four-cylinder, DOHC VTEC, 16-valve
- Bore: 85.0 mm
- Stroke: 88.0 mm
- Displacement: 1997 cc
- Torque: 145 lb?ft (197 N?m) @ 5500 rpm
- Horsepower: 200 hp (150 kW) @ 7000 rpm
- Red line: 7400 rpm
- Compression: 11.0:1
- Fuel control: OBD-2
I can also provide swap service if needed. Please contact on given contact number for further info.
Demand: 130,000/- only (slightly nego)
Contact:
Burhan Rafique
0321-4393143
