I want to chng the exhaust system of my cuore just to build some sound out of it, which exhuast to be used and what abt tuneable exhaust..? and also doesl chng of exhaust pose any threat to engine..?
Yes it does, Alto already has a very vulnerable engine so I wouldn't recommend to do so but if you do want to then buy any, doesn't make a difference.
If u are just looking for increase in sound, replace the small dholki under your driver's seat with a straight pipe. Voila, more sound
Sent from my GT-I9500 using PW Forums mobile app
that is quite harmful for the engine, no? all the carbon back firing in the engine and too in opposite direction?
should be harmful for the environment only..........
This can cause the engine to cease as well.
Removing middle dholki and silencer both will not harm engine in any way...infact it will increase the performance as both these things resist exhaust gases from escaping to atmosphere and in return reducing sound....but it is highly NOT remommended as there is something in civil societies called 'ethics of living'.... you car will become very noisy without these causing nuisance to others
Sir how can this be not harmful for the engine?
Silencer has restrictions built in it....that absorbs/depletes sound energy produced by the engine...it also restricts exhaust gases from escsping during this process causing some back pressure on the engine and lowering its performance....when you remove it engine can inhale and exhale much more smoothly...
Sent from LG Optimus LTE LU-6200 using PW forums mobile app
