Here is what recently mechanics did to my car,
i went to tuning, it was namaz time, i went for namaz, when i came back everything was done. Then i found following,
- Makkah of my headlight removed, results was that head light was on free fall.
- CNG and fuel mixture setting destroyed, result, too much gas comsumption, 4 - 5 sulfs on start, too much vibration, and so on...
- Headlight relay broken, light does not work on high beam.
- Clutch wire setting destroyed, having hard time pressing gears, when i went back they asked that its gear problm, they will have to remove all gear, and will change clutch, pressure plates etc......
- AC fan relay destroyed, i did not know but i thought the gas had leakd coz the cooling was dam gone. They asked that they will need to refill gas again. I later went to electrician and he fixed the relay in 200 rs in jinnah supper behind petrol pump.
- Car deck and other wiring underneath dashboard broken, results, sometimes things work, sometimes not....
May Allah give us Sirate-Mustaqeem....
Loss:
Had to visit many mechanics to verify the problems, spent around 3000 including petrol and gas charges, when there was nothing at all problem, was just masty of mechanics.
these mechanics are so intelligent that sometimes you will find these problems when you gone off their workshop. this is what happended to me.
Results:
Either be aware or make suggest what can be done to cope up with these fraudy mechanics....
