Hi Bro i hope this article is helpful for you.
A diesel engine is more easily turbocharged than a petrol engine. A petrol engine cannot be easily turbocharged due to the fact that if the compression ratio and the pressure in the cylinder is to high during the inlet stroke, the mixture starts to burn to soon, while the piston is on its way up. The diesel engine has no fuel in the cylinder, thus letting the turbocharger suck as much air as it can without creating any problems. (A turbo charger is a simple air compressor which compresses air in the combustion chamber for burning). Some diesel engines also have an intercooler which helps in blowing cold and oxygen rich air in the combustion chamber.
Electronic engine management not necessary in diesel engines. Some modern diesel engines are gaining electronically controlled injection pumps, but the vast majority of them out there have purely mechanical pumps. In fact no electricity is required to make a diesel engine run, except for a simple fuel cut off solenoid so that you can switch the thing off! If your alternator stops working, then you’re gonna get home in a diesel. This also means that a diesel engine does not have any ignition breakers, ignition coils, distributors and ignition wires to go bad. So a diesel engine should start no matter if it is dry or rainy or wet.
Petrol destroys lubrication and burns the engine whereas diesel doesnt. So a diesel engine would last longer than a petrol engine.
Petrol engines are lighter than diesel engines.
Diesel engines have higher torque than petrol engines. What does this mean? Well, this means that a diesel engine would pull heavy loads easily than a petrol engine. Though the pickup of a petrol engine would be much more than that of a diesel engine, the diesel engine would be steady and carry heavier loads to longer distances.
Diesel engines have better fuel efficiency as compared to petrol due to the fact that they have higher compression ratio.
Diesel engines dont need an ignition system, which reduces their complexity. But they are more noisy and may require frequent maintenance as compared to petrol engines. Also they are more durable.
Diesel engines may also need glow plugs in extreme cold conditions which heat up the cylinder so that a cold engine can start easily.
And now the most important part, fuel economy. Diesel wins in both ways. Diesel engines give better mileage than petrol engines.
About D4W engine.. i don,t have any idea about this coz this is a search engine .maybe you are asking about modren D4D diesel engine,
D-4D actually stands for direct Injection 4 Cylinder Common Rail Diesel Engine. Common rail diesels inject a fine mist of fuel into the engine at very high pressure. The result is the same power and refinement as a petrol engine, but with better fuel efficiency and lower emissions.
Toyota D-4D engines are not just noteworthy for their smooth, linear torque, though: that's a characteristic of most modern diesel engines. What D-4Ds are noteworthy for is their unusually high power outputs, equivalent to that of many competitors' similarly-sized petrol engines. The D-4D's rev range is also usefully wider than normal, further enhancing the driving experience.
