Devils Pride
https://www.pakwheels.com/forums/general-4x4-discussion/201695-landcruiser-kzj-70-sheryar
Stepped Up To New Series
Was A True 4x4 Project & Enjoyed To Way High
But Now Game Is On For New Project
Toyota LandCruiser 80 Series (FZJ80)
Make : Toyota Land Cruiser 80 Series (FZJ80)
Year : 1997
Body Color : Golden/Sliver (Satin Bitter Yellow)
Body Shape : Squared 5 Door
Suspension : Soft/hard
Engine : 1FZ-FE (4500cc)
Fuel Type : Petrol
Transmission : Auto 4x4 (LSD)
Wheelbase : Long
Interior : Brown/Oak
Options : Sunroof, Power Windows, Power Lock etc
Token : 07/2017 Paid
Condition : All Stock So Far With No Accidents Or Touch-ups
Jeep Club : ZOR (Zalmi Offroad & Rally Club)
Purchased Date : 23rd March, 2016
Offroad Wider Atric Fender Flares (Installed)
DEPO 6 Piece Set Front Head Lights Crystal (Installed)
TJM Short Roof Carrier + Wind Deflector (Installed)
ARB Awning (Small) (Installed)
3M-1080-S335 Wrap Satin Bitter Yellow (Installed)
Interior :
All Original
Engine & Gear :
NGK IRIDIUM (IX) Spark Plug - 6 Pieces (Installed)
Aeromotive 11140 Fuel Pump 340lph Stealth Pump (Pending Installation)
Magnecor 65234 8.5mm KV85 CN Series Ignition Cable
Nitro 4.88 Ratio, Nitro Front & Rear Gear Kit (Installed)
The "TRU FLOW" Toyota Timing Chain Kit (Installed)
50mm 13 Row AN-10/AN10 Double - Deck Oil Cooler Hose Filter Relocation Kit (Pending Installation)
Exhaust & Headers :
Borla Cat Back Exhaust System Purchased.(Installed)
Genie Headers Long Tube Set (Installed)
MangaFlow 23622 Catalytic Converter Front (Installed)
Kool It Heat Warped On Header(Installed)
Kool It Heat & Rust Proofing On Headers (Installed)
Heat, Rust & Sound Control System :
DYNAMAT 72 Sq ft Heat & Sound Proofing Inside (Installed)
Rubber Coating Water & Rust Proofing Under Fenders (Installed)
Suspension, Break System & Axles :
4" Lift Kit Stage-2 Suspension Package " PEDDERS " (Australian Brand For Suspension Solution)
1.5" Front & Rear Polyurethane Coil Springs Spacers(Installed)
The 4" DropBox Kit (Installed)
Nitro Chromoly Birfield & Axel Kits (Installed)
30 Spl, Nitro Chrmoly Rear Axel Kit (Full Float, Pair) (Installed)
Heavy Duty Axles & Bearings Kit by NITRO (Installed)
Draglink Chrome Moly 4140 Steering Arm 38mm (Installed)
Solid Chrome Moly 4140 Tierod Rock Rod 38mm (Installed)
Heavy Duty 1310 CV Double Cardan Front Driver Shaft (SPICERS) - (Installed)
Wheels & Breaking System:
Mickey Thompson Baja Claw Radial 35x12.50R15 (Installed) Used For Offroading
Mickey Thompson Rims 15" Light Weight 10" Wide (Installed)
Coopers Tires Discoverer A/T3 37x12.50R17 (Installed) Used On Road
Lenso 17" Light Weight 9" Wide (Installed)
G2 1.5" Wheel Spacer Black Coated Aluminium (Installed)
The Hawak Performance LTS Brake Pads Front Set (Installed)
The Hawak Performance LTS Brake Pads Rear Set (Installed)
AOE (American Offroad Expeditions) Front Off-Road Bumper- USA(Installed)Adventure-4x4 Rear Off-Road Bumper - Australia (Installed)
Winch Warn Zeon 10 Premium Series (Installed) K&N Gold Oil Filters (Installed)K&N Pro Oil Filters (Installed) K&N Air Filter (Installed) ARB Safari Snorkel V-Specs SS81HF (Installed)HPS RED Reinforced Silicone Radiator + Pesky Heater Hose Kit (Installed)
Rigid Industries Radiance 30" Red Back Light LED Bar - 23002 (Installed)
Rigid Industries Radiance 50" Red Back Light LED Bar - 25002 (Installed) WL Series LED - PN 93920: 4" LED Lights Spot - Pair (Installed) (Installed 09/11/2016)
Head Unit
Pioneer 7" DVD Head Unit .... (Installed)
Front Stage
Pioneer Components ....
(Installed)
Focal FP 2.150 LE Amplifier (2 Channel Dynamic Capacity 1 x 400W rms available into 4 Ohms)
Rear Stage
Pioneer Components .... (Installed)
Focal Solid 4 (400w 4 channel amplifier, With 4 x 75W RMS power into 4 Ohms and 4 x 100W RMS into 2 Ohms)
Woofer : .... (Installed)
Kicker S15L7 Solo Baric (2012 Model)
Kicker ZXS 1000.1 Amp (2012 model)
Monster 202LN High Performance RCA 5m Lead 2 Channel.
Kicker PKD1 3000watts 0 Gauge 6.1m +ve & 1m Ground / Kicker Fuse Box Kit
Kicker Woofer Safety Grill
06-11-2016
"I M Not Crazy, My Reality Is Just Different Then Yours "
23-10-2016
25-09-2016
07-07-2016
25th June 2016 - Installed Only Suspension + Wheels
