!--[if gte mso 9]xml w:WordDocument w:ViewNormal/w:View w:Zoom0/w:Zoom w:PunctuationKerning / w:ValidateAgainstSchemas / w:SaveIfXMLInvalidfalse/w:SaveIfXMLInvalid w:IgnoreMixedContentfalse/w:IgnoreMixedContent w:AlwaysShowPlaceholderTextfalse/w:AlwaysShowPlaceholderText w:Compatibility w:BreakWrappedTables / w:SnapToGridInCell / w:WrapTextWithPunct / w:UseAsianBreakRules / w:DontGrowAutofit / /w:Compatibility w:BrowserLevelMicrosoftInternetExplorer4/w:BrowserLevel /w:WordDocument /xml![endif]--!--[if gte mso 9]xml w:LatentStyles DefLockedState=false" LatentStyleCount=156" /w:LatentStyles /xml![endif]--!--[if gte mso 10] mce:style! /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} --
Hello everyone!
Yet again, I need your help and advice. Though the problem is not a huge one but still would like to hear from you all before I decide anything
Anyways, I have a Nissan Sunny with a GA15DS engine. The problem is with the car air conditioner. Once the gas is filled, the pressure will not drop for hours but the gas goes in air after about 2-3 days. Have checked for leakage, the pipes are fine, the filter (bottle) is fine, the front condenser is fine. Now only two things remains, the compressor and the unit inside the car but according to the ac mechanic that pressure goes down only when the compressor is turned on that shows the leakage is in the compressor and not anywhere else.
The compressor is the original, which comes along GA13/15 engines. I have got the washers changed but still the same problem. Now the ac mechanic is saying that we should change the compressor and he is for a Senden 507. And he thinks that a Kabli which will cost around 4500 is much better than spending 10-11k on a new one. But he is very much against going for same sort of compressor which is factory fitted according to him such compressor wont even last for s single season (but the my problem is this compressor did last for over 15 years so cant another such kind can last for few years?)
Anyway now need your ideas, what should I do? Should I go for a Senden? New or a second hand? (the difference of about 6-7k is huge, specially if we are talking about such a old car).
By the way anyone selling a Senden 507 (in good condition) do let me know.
