Can a one phase apartment bear the load of two 1.5 tonne air conditioners and a fridge as well as a geyser or should it be converted to three phases.
It seems that one of the two air conditioners continually develops a leak recently under warranty the cooling coil failed and was replaced . I am wondering if this was because the apartment cannot handle the load. When both air conditioners are on. Some people say it should others confused . I would like some expert opinions .
Also what is the best way to check load capacity of the apartment through voltage or ampere reading and from where? The main Kesc box meter box or the box inside the last.
When last checked from an extension board the voltage was 218 volts and the ampere reading from the Kesc box was 0.18 or something of the sort.
Would like some opinions
Thanks
It's quite important and urgent
