Three possible reasons:-
1) Clutch/friction disks do not properly disengage due to clutch adjustment
2) the idle speed is too high or you have the tendency to ride the throttle while shifting gears
3) Faulty gear changer or sprockets
Considering it is a wetsump monoblock engine, I cannot imagine the lubrication system being faulty. Are you using the correct lubricant?
