Electronics market, college road, <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com<st1:place w:st="on">rawalpindi</st1:place></st1:City>………….
Every type of led’s are available at college road <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com</st1:City><st1:place w:st="on">rawalpindi</st1:place>….. the led’s we are talking about are known as Laser LED’s in local market…Led;s are avalible but some shops are selling them too costly then their original prices….!Like (saeed electronics, shaheen market, college road <st1:City w:st="on"><st1:place w:st="on">rawalpindi</st1:place></st1:City>) are selling too costly….5 watt led rs400/-10watt led rs600/-20 watt led rs1500/-50watt led rs3000/-100watt led rs7000/- <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comAnd some are reasonableLike (hafiz electronics, shaheen market, college road <st1:City w:st="on"><st1:place w:st="on">rawalpindi</st1:place></st1:City>) …… but they have only up to10watt… but u can place an order to(Hafiz electronics) for higher watt led’s and they will give u in reasonable prices…10 watt rs100/-<o:p></o:p>But there are many shops to explore and hope u will get them in reasonable price..(Personal experience) …hafiz electronics have reasonable prices for almost every type of electronics components….<o:p></o:p>
bro check this link for high power leds based in lahore
high power super bright led 10watts for sale Rs 370high power 10 20 30 50 and 80Watt leds in nominal prices... Colour :pure white Voltage: 10-12v Current 1-1.2A Emitting angle:140 degre Luminous flux: 750-800LM usefull life: 10000 hours
high power super bright led 10watts for sale - Lahore - Electronics - new campushope this will help you.
bro cat light fit krwa lo
bump, any viable solution to the problem found yet ? ? ?
no .. i tried few leds ut there light cannot be focused into a beam.. they need special optics and reflectors .. which are hard to come by
i told you about that the main thing is custom reflector or optics how ever you can get reflector from chines torchs which have 10 to 12 leds
even i made lights in which i used custom reflector made by me and used 2 10watt led every thing was fine but motorcycle wasn't giving required voltage
pics ? i will do this experimetn some time...
have u tried any boost circuit for that ? kia boost driver circuit bana banay athay hai ? i found few drivers in pindi but they were extremely expensive like 300rs for just 1 watt led .. and moreover it were speclesss .. seller didnt know its topology
asjdsm: You can see the difference between these two lamps stock is a crystal and after-market is simple.. this is the reason HID doesn't produce good light in after-market lamps.
i have bosster but i use it on my 100watt led.To run 10 watt led i just need was 11.50 volt i used 9 ohm resistor
any solution found ?
any solution found ???
for what?
Slam brothers my Father is using 86 model cd honda 70 I completly changed it into big honda 70 current one shape. problem is electrician was saying its 2 coil bike and new bikes are 5 coil so thats why bike light is very dim (not good) so whats solution I should do bcoz he was saying to convert into 5 coil will be very very expensive so brother kindly share any solution for specially headlight
how much volts your bike is giving?
Now my battery is 12 volts with complete changed wiring and cutouts for 12 volts but light is dim bcoz of 2 coils
We tried to use 12v 25w bulb in 86 model CD without electrifier, but it got fused because of overload. So basically, it is producing more than required current anyway, then why bulb still dim???
Sent from my HTC One X using Tapatalk 2
it might have been fused due to unstable current
Brother, you can consult with a good electrician as there are many factors affecting the light i.e.
