Salam I want to know to know that how do I get rid of weird noice like khatak while shifting the gears my bike is unique ud 70 and it is under the warrenty.
Mostly its because of loose Chain.
Is key ilawa kya reason ho sakta hai ? Engine men to problem nhe hoti kaheen.
Sent from my Blade III using Tapatalk 2
Since it is warranty, better get checked in warranty. There can be some problem with clutch plate or clutch bearings too or gear sprockets in the worst case.
Try to get it fixed under warranty dont go to any road side machanics till the time its under warranty. Though you can take advice from any mechanic by showing him the problem.
Unique ka hamesha ka masla hai....gear shifts are not smooth and make a lot of noise....... thori awaz chain ki hoti hai......remaining gearbox say aati hai. I have these noises since 2008 when i bought one new...... in my experience....its nothing to worry abt......but just for the peice of mind....get it inspected under warranty
Get your timing chain checked
nothing to worry bro... this sound is present in most chondas... there's is a sweet spot to change gears in these bikes.. once u get the hold of this.. there will be no noise...
Sent from Mars using Mind Control
