I have super power 70cc 2011 model 27k on odo.the problem is its gear shifting became very hard and sometimes gears are sticking between previous and next gears.i change its oil after every 500kms.and I am using zic 4T 20w40 or shell advance 20w40 (red bottle).i hope u ppl understood:)
Sent
Shifting gears become harder is the sign of worn out clutch plates.
.....or clutch cable needs proper adjustment!
Yes i am also thinking to change it.mechanics telling diffrent causes of this issue.BTW Can u plz tell me good quality clutch plate for my bike?PS i am newbie to bikes
Sent from my ST25i using Tapatalk 2
Can i do it my self?
CLutch adjustment karwain,cable main play ziada kar kay check karain.Worn out clutch plates at 27k exhibits bad shift management.Clutch plates replacement should be your last resort.DOes you engine whine at high rpms?
No it doesnt whine...wese bro clutch plate ki kya cost hogi and which brand is suitable?
Bhai i asked something :S
why don't you get check gear rubber in rear wheel drum.very cheap I guess genuine @ Rs. 150 + Rs. 80 labor fitting
Also check whether chain is too tight or loose.
They are 4/4
Chain is okay.clutch plate is the issue.but i dont have a good mechanic to change it
