I will not take it to 50 km/hrI shall take it to maximum 25 km/hr.Two reasons:I dont know yet the stability of this cycles frame.The brakes are not good enough.
Sent from my QMobile Z10 using Tapatalk
I have a very reliabke digital speedometer. I shall install it on motorozed bike soon. But i do noy intend to race this cycle to full speed [emoji14]I am not yet frienda with this Cycle frame and braking
Great work brother awesome its looking good but did you place rubber in mounts because is can't see it whereas design of mounts impressive just at the right position again great work brother
I forgot to place rubber ![emoji15]
Can i use cut pieces of tyre tube ?
Piece of tube around rod then tightening engine screws around it ??
i'm just thinking the same use piece of tube to decrease vibration...have you take a test drive if yes then hows the experience and did you feel vibration's of engine??
I just took test drive . i m feeling too much vibration at low rpm [emoji14]
And , my brakes are not good at all !!!
Engine works so beautiful !! Smooth ,
yes and keep the size of tube slight bigger then mounts i think tube of bike will remain weak try to use cars tube.
Right ! Good ho gya
While tightening nuts and bolts how much should i tighten a nut ! I m tightening maximum , forcefully !
How did you put the race handle?
BTW nice DIY and Congratz
Next should be the mini car
yes brother tight forcefully but keep an eye on the piece so it don't start cuttingusually it cuts in pieces if we tight it too much one more thing it is not reliable means don't last long but its the easiest way.
It came with engine. .Carburator mei setting ki youtube video dekh kr
Impressive project man. Hats off to your effort
Bhai, people who have already mounted engines to cycles they say do not place rubber between engine mounts and cycle , reason they give is tgat screws in engine mounting will be broken too soon then..now i am confused about this.And let me show u latest photos.
Thanks , its done but i am still learning from expertise of people here. I am new to engines
Can't understand the reason...whereas if we not place rubber or something like that then how to reduce vibrations?
Yes , yeh smjh say baher hai. Unka kehna hai engind ko hold krnay walay screw ragray jatay hain isi liay china sath rubber pads nhi bhaijta. Lekin aqal nhi manti yeh.
Newer photos:
Top speed so far [emoji14]
Chalo bhai kuch nae hota leave it as it is and Just ENJOY
I don't think so. My recommendation is use Kabili Bolts and Chuk Nuts and place tube. it shouldn't break at all.
