Salam,
HID light is best source for more brightness nd visibilty nd make your Vehicle sexy, bt its costly if u bear all chargis then u must install in your bike,
HID light ( High-intensity discharge lamp ) consume 35 watt same like as Orignal deluxe bulb also consume power 12 volt 35 watt. But orignal light runing through MAGINET. thats y it will b not effect to battry. HID runing through Battry, This tube is filled with Neon gas and metal salts need hight voltage to arc nd heat the gas, and Orignal bike battray not enough for HID . Because this battry only 12volt and 2.5A
Hid light need high voltage using Blaster. i also installed Hid in my Honda Deluxe 125. And its work perfectly and work up to 2 hours and more then.
installation parts for HID..
(1)
buy ( 8000K H4 Temperature HID light+blaster) . its cost about 2k with 6 month warranty,
( This is a pair of 2 lights) 1 HID or 2nd is incandescent flament tube ) Incandescent Tube same like as Default honda bulb yellow light, it will work on low beam through MAGINET current. and HID work on high beam button through Battry currnet. when u use high beam Incandescent Tube automaticaly will b off nd HID will b work,
This pair will b adjust in place of Orignal bulb holder in 30 sec. Deluxe light body is very biger like car light body, it bear the HID Heat easily no modification needed.
(2)
Install 12 volt 9Ah National battray, its easily available in market with 3 monts warranty cost about 1.5k. its adjust very easily because deluxe has biger space in battry panel, no need to modification.
Use china Road prince Rectifier. its provide auto current Ah 2.5 Ah to 7Ah step by step when battary needed,
(NOTE)
(1)
Always use ( 8000K H4 ) temperature HID light. This colour temprature is white+blue. This temp never too much blind to other Drivers. Dont use HID Dipper (flash) on single road but trafic runing on both sides' it will be blind to other nd dangarious like a road accident, but if you use HID continusely without dipper then no problem. better option is Try to use only one way Roads.
Use HID Only when bike engine in start position, it will b battray backup increase,
(2)
Installation HID to only expert electrician. because this is very inteligent work. Many Relays, junctions cut out and reactifier put in this circuit, every electrician not knowledge about how HID perfect work in bikes, dts y result will b shown also in bad experience like hid burn,blaster burn,battray not proper charging, battary over charging, bike current problems, MAGINET problems etc etc,
i have contact number of a expert Electrician sepcialy for Deluxe nd other bikes, His shop in mecload Road lahore, he installed many HID lights in deluxe nd also normal cg honda 125 nd 70 cc bikes bt no complain,
Here is contact number: 0307 6176832, Refer to ( Asif Aslam )
if u want to further information then text me. My email ID is ( Asifaslam_43@yahoo.com)
Dua mai Yaad rakhiye ga... Allah Nigheban
