Install a liquid cooling system in the engine. Right now it seems air cooling is not enough.
You can even make your own system using water tank, some cast iron pipes and small motor pump. Pipes need to be wraped around the engine and connected to a motor. Water will be pumped around the pipes keeping the bike cool.
Sent from my SM-J700H using PW Forums mobile app
