Results 1 to 3 of 3
Thread: suzuki f8b engine tunning
    drtanveerali's Avatar
    Apr 2009
    Select City
    39
    1,303
    7 Post(s)
    Default suzuki f8b engine tunning
    I FOUND THIS TOPIC ON NET AND WANT TO SHARE IT WITH ALL OF YOU. AS SUZUKI F8B ENGINE IS INSTALL IN SUZUKI MEHRAN, BOLAN AND RAVI.
    [img]SuzukiTuning/AltoTuning/Pictures/Suzuki%20Alto%20with%20tuned%20F8B%20engine%20at%2 0top%20speed.jpg" width=321[/img]
    Do you want to see this on your speedometer after tuning your Suzuki Alto / Suzuki Hatch?
    table width=100%"
    tbody
    All the Suzuki Alto's sold in the Netherlands have the same engine/platform. So it is very cheap to maintain, because second hand parts can be found at almost any junkyard and are cheap! The same car and engine are also sold as the Daewoo Tico and in India as the Maruti 800. The F8B engine is also mounted in the Suzuki Mightyboy and Suzuki Hatch.
    General specification:
    Engine code: F8B
    Capacity: 796cc
    Nominal bore: 68.5mm
    Stroke: 72.0mm
    Compression ratio: 8.7:1
    Max power output: ]29.5kW/39.5bhp @ 5500rpm
    Power output per litre: ]37kW/49,7bhp
    Power to weight ratio: 64,1bhp/ton (616Kg)
    Max torque: 59 Nm @ 3000rpm
    Torque per litre: 74,1Nm
    Torque to weight ratio: 95,8Nm/ton
    Intake 31.6mm Exhaust 27.6 (valve head diameter)
    Rocker ratio: about 1.48
    [img]SuzukiTuning/AltoTuning/Pictures/Suzuki%20F8B%20Engine.jpg" width=402[/img]
    /tbody
    /table
    4 speed F8B gearbox gear ratio's:
    table width=300"
    tbody
    Gear
    Gear Ratio
    Speed Ratio
    43/12
    3,583
    39/18
    2,166
    32/24
    1,333
    27/30
    0,900
    Reverse
    37/22x22/11
    3,363
    Final
    87/20
    4,350
    /tbody
    /table
    So you don't need a lot of extra horsepower, or a lot less weight, to make driving your Suzuki Alto much more fun!
    Tuning your Suzuki Alto consists of increasing the compression ratio, enlarging the intake ports and larger in- and exhaust valves. You can also remove some of the camshaft spline on one end, so you can alter the camshaft timing a few degrees!
    By increasing the compression ratio to about 9.5 you will get much(!) better throttle responce, more power and more torque. The downside is that the engine will vibrate slightly more when idling. Even with a compression ratio of 9.5:1 it was impossible to get the engine to "pink" or get it to the point where detonation or pre-ignition occurs. No matter where you put the ignition timing. (Tested on unleaded 95 and BPR6ES spark plugs). Because the head sits lower on the blok, you get different, read retarded, valve timing! Tuning the valvetiming is pretty difficult, I filed one side of the camshaft spline, so you can alter the camshaft timing a few degrees!
    General guideline to engine tuning: "The 80% Rule". Which means that the intake port area should be max. 80% of the intake valve area, the exhaust valve area should be about 80% of the intake valve area and the exhaust port area should be 80% of exhaust valve area!
    In a lot of engines the 80% is already applied. so you can just use the exhaust valve to check the intake port area. It should be a tight fit. In case of the F8B engine is the exhaust valve area is 76,3% of the intake valve area.
    table width=100%"
    tbody
    [img]SuzukiTuning/AltoTuning/Pictures/Suzuki%20Alto%20F8B%20Head%20mounted.jpg" width=400[/img]
    The cylinderhead still mounted on my 1985 Suzuki Alto F8B engine, just removed the valve cover.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20Head.jpg" width=400[/img]
    This is how the head looked like, when I took it off. I have had the head skimmed by 0.85mm to increase the compression ratio to about 9.5 instead of 8.7 to 1. Skimming the head by 0.85mm will just skim the squich area (the bump on the bottom left of the combustion chamber). Do not forget install the BPR6ES sparkplugs instead of the BPR5ES! Otherwise your engine starts pinging at around 105kmh. (Glow ignition!)
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20Intake%20port%20cyl%201.jpg" width=400[/img]
    You can clearly see the obstruction in the inlet port. So you know what to do... Bore the intake port to a nice round 28mm in diameter. Tip: You can use the exhaust valve to measure the diameter, and at the same time to see if the port is nicely round! You can also use 3 28mm wood drills to get the size right.
    Note: No carbon deposits on valve or intake port. So in original configuration there are extremly high gas speeds!
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20combustion%20chamber%20intak e%20valve.jpg" width=400[/img]
    Smooth the edges in the combustion chamber next to the intake and exhaust valve seat. This will increase torque significantly. Polishing the combustion chamber prevents carbon buildup.
    [img]SuzukiTuning/AltoTuning/Pictures/Klepgeleider%20en%20klepkoprand%20cilinder%20(2).j pg" width=400[/img]
    A closeup in the inlet manifold: you can see the rough finish near the valve seat. Remove all the roughness and the
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/F8B_Worn_%20Rocker.jpg" width=400[/img]
    A close inspection of the rockers revealed that one of them (exhaust side) was totally worn.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20Worn%20Camshaft.jpg" width=400[/img]
    The same wear pattern shows up at the camshaft. Replacing both camshaft and rockers is the only solution to this.
    Although I do not have a picture of the intake manifold, you will have to make sure the diameter is enlarged to about 27mm. An easy way of doing this is buying a few 28mm stealbrushes that fit in a drill. For the curved channels you have to use an extension (5mm tap end) that fits through the vacuum hole on the left. Tip: You can use the exhaust valve to see if the diameter is OK.
    [img]SuzukiTuning/AltoTuning/Pictures/Slijpsel%20inlaatkanaal%20cilinder(1).jpg" width=400[/img]
    Make sure you have the same amount of aluminium alloy dust laying on your bench after you fininshed working on one port of your head.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20at%20full%20speed.jpg" width=400[/img]
    No comment, oh wait, just one: The Netherlands is flat!
    [img]SuzukiTuning/AltoTuning/Pictures/Suzuki%20Alto%20with%20tuned%20F8B%20engine%20at%2 0top%20speed.jpg" width=400[/img]
    The result after tuning... Nice and off the scale! Almost 160! Not bad for a tuned 796cc engine! Expect acceleration times from 0-100kmh (60mph) in about 13 seconds. My personal record is 165, this was with 145/80/12 tires, which are 10.6% larger in diameter, and "spot on" 150 on speedo.
    Also remember: after tuning the F8B you should not drive it that hard without proper cooling; After 10 minutes of driving to the max you will get oil temperatures of up to 160 degrees C! I did not do anything about it, only regular oil changes and semi-synthetic 10w40 oil. Perhaps you can install an oil cooler, or build a water to oil cooler yourself.
    /tbody
    /table
    Although I do not have experience swapping the engine with the F8C motor of the
    Daewoo Matiz
    , it must be easy to do! The same block with different head, multipoint injection and the alternator on the back of engine. It also comes with a 5 speed gearbox. Puts out 52bhp@6000rpm, and 69Nm@4600rpm. You will get a power to weight ratio of 84pk/1000Kg. Something you will definitely like! Imagine adding a smallish turbo charger to the F8C engine! The new Chevrolet Matiz engine (2005 onwards) has roller rockers and they lower valvetrain friction and valvetrain noise a lot!
    table width=100%"
    tbody
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Daewoo%20F8C%20Power%20Torque%20Output%20chart.gif" width=340[/img]
    The output curve of the F8C engine. Compared to the stock Suzuki F8B engine it has a 30% increase in power and 17% increase in torque. Almost the whole torque curve is above the original 59Nm! (1800-6200rpm) Click image for better resolution. (This is F8C without roller rockers)
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Daewoo%20F8C%20Head%20Combustion%20chamber.jpg" width=374[/img]
    This is a pictures of the bottom of a Daewoo Matiz cylinderhead. Stated compression ratio is 9.3:1 Although the picture is not really clear, there are bigger valves mounted; Compare the pictures below. Also, you can still see rough edges near the valves. If you decide to mount an F8C engine, please take the head of and smooth the edges near the valves. The used valves on the F8C engine are 35.6mm and 31.8mm in diameter, but it is not going to be an easy swap, the valve stem size is 5.5mm instead of 6,97mm! Intake area for intake valve is 27% larger and 32.8% larger for exhaust side, exhaust valve area is 79,8% of intake valve area.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/Suzuki%20Alto%20F8B%20Head%20compare%20F8C.jpg" width=400[/img]
    Original valvesizes are: Intake 31.6mm Exhaust 27.6 (valve diameter)
    /tbody
    /table
    If you want to swap valves on the F8B head, you can try the intake valve of a
    Peugeot TU9
    1 liter engine. Intake valve diameter is 34.8mm (21% larger). The valve stem diameter is the same, although the length differs a bit: 109,4 mm original compared to 112.76. The spring retainer is original at 102,1mm but the TU valve is higher at 108,75mm, so you will have to experiment with the spring retainers. You can adjust the longer lenght with the standard rocker adjusters.
    If it fits, not tried!, you can also try a bigger exhaust valve of a Peugeot/Citroen TU3 or TU1 series engine. These are 29.4mm in diameter (13% larger), and have the same stem diameter.
    You can also look for the valves that are used in the Suzuki G10A engine, the intake is 36mm and exhaust is 30mm. But I doubt if they will fit. (Read: not hit each other when opening). The valvestem diameter is the same, so it is an pretty easy try.
    Rocker ratio of the F8B engine is ABOUT 1.48, and 45degrees. Unfortuately I do not have have a picture of the aluminium rockers off the F8C engine nor from the new roller rockers.
    Ofcourse you can also look for the F8C Daewoo Matiz valves. A complete F8C engine swap, with gearbox and ECU will cost about 800 euro for an engine with 70k on it.
    table width=100%"
    tbody
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/IMG_0012.jpg" width=400[/img]
    On the left the retainers that came of my 1985 Suzuki Alto. On the right, also from a Suzuki Alto, but year unknown!
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/F8B%20Valve%20retainer.jpg" width=400[/img]
    The spit collets. Look at the difference in notch height.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/F8B%20TU3%20differences.jpg" width=400[/img]
    On the left the TU3/TU1 exhaust valve. Slightly longer, but not as much as you see on the picture: the TU3 valve itself is slichtly thicker. About 0.5mm.
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/F8B%20TU1%20exhaust%20valves.jpg" width=300[/img]
    [img]SuzukiTuning/AltoTuning/Pictures/400x300/F8B%20Valve%20retainer%20height.jpg" width=400[/img]
    Result: equal height! You will have to remove about 0.5mm of height on the left because the valve itself is thicker. (and also slightly heavier). The spring pressure will increase a bit which is convenient, because of the weight.
    /tbody
    /table
    You can also look for the Manual transmission of a Daewoo Matiz, mountings should be the same, but the gear is cable selected!
    The Daewoo Matiz 5 speed F8C gearbox gear ratio's:
    table width=300"
    tbody
    Gear
    Speed Ratio
    3,818
    2,210
    1,423
    1,029
    5
    0,837
    Reverse
    3,583
    Final
    4,444
    /tbody
    /table
    suzuki f8b engine tunning - logo110x110 width80
    the link is http://www.suzukituning.com/SuzukiTu...AltoTuning.htm
    www.dr-tanveer.com
    Apr 2009
    Select City
    39
    1,303
    7 Post(s)
    suzuki f8b engine tunning -955313
    F8B ENGINE
    suzuki f8b engine tunning -955314
    suzuki f8b engine tunning -955315
    suzuki f8b engine tunning -955316
    suzuki f8b engine tunning -955317
    suzuki f8b engine tunning -955318
    closeup
    suzuki f8b engine tunning -955319
    suzuki f8b engine tunning -955320
    suzuki f8b engine tunning -955321
    suzuki f8b engine tunning -955322
    suzuki f8b engine tunning -955323
    suzuki f8b engine tunning -955324
    suzuki f8b engine tunning - 13 Y53 PakWheels com
    suzuki f8b engine tunning -955325
    suzuki f8b engine tunning -955326
    suzuki f8b engine tunning -955327
    suzuki f8b engine tunning -955328
    suzuki f8b engine tunning -955329
    suzuki f8b engine tunning -955330
    suzuki f8b engine tunning -955331
    www.dr-tanveer.com
    Proverbial_Slang's Avatar
    May 2005
    3,856
    29 Post(s)
    Very nice! This is one of those legendary engines which have been bread and butter for Suzuki.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
