I recently purchased a mehran and its cylinder looks old i want to test it in karachi where can i do it?
go to HDIP in Korangi .. Its near CBM Campus...
@jacer,
before going there check the embossed date on your CNG cylinder .. HDIP wont except you cylinder even if 1 day is remaining on completion of 5 years .....
what i get that they will check post 5year cylender only?2ndly what is their method of testing?
refresh. . .
I think you should better ask them via Phone.. get their Contact number from someone.
they will simply keep ur cylinder for a week or two and they will fill the tank wid 400 -500 Psi and they will check the durability if it is able to fulfill their requirement then they will emboss the date of current most probably they put a hole and reject it
buy a new one.
@all,they test the cng cylinder on high pressure plant .... and if your cylinder is fine they paint it and issue you a new certificate of another five years .... and a sticker on your car ... if your cng cylinder is not up to the mark they cut it half infront of you and through it in junk ....
We want to cooperate with you to set up CNG cylinder testing station
We could provide CNG cylinder automated ultrasonic inspection system and train
Please contact me via ndt@cdint.com , if you are intrested in it .
Hello, aantherax, are you online?
