yep the ECU will store the code until reset by a battery disconnect, check and post back the sequence of flashes you get, The modern toyota way is
first set of flashes = 10
second set = 1
meaning flash flash flash flash pause flash = 41
codes are displayed as - shortest to longest and will have gaps in between them.
regular flashing with no pause = everything normal
