Page 1 of 8 123 ... LastLast
Results 1 to 20 of 146
Like Tree10Likes
Thread: CNG TUNING How to do it
    Gulsher's Avatar
    Dec 2005
    66
    38
    Default CNG TUNING How to do it
    At times one needs to fine tune the adjustments on the CNG system.
    We all know it is just a pressure regulator under the bonnet with a bypass probably in the third stage to allow for idle etc.
    I never had a closer look at the thing but I expect to find just two adjustible screws, one for the setting of pressure and the other for idle speed adjustment.
    BEFORE I VENTURE into it, I would please like to know if someone here actually has the experience of adgusting the Italian CNG kit. PLEASE tell us in details how to do it
    Thanks
    c123pk's Avatar
    Apr 2005
    39
    12,622
    10 Post(s)
    All you have to do is to Drain the oil from the regulator, if your car has done some 25 to 30k.
    There is a screw at the bottom, just drain the oil and tighten the screw up, thats all
    spectra's Avatar
    Jul 2005
    40
    19,658
    299 Post(s)
    22 Thread(s)
    drain oil as c123 has described.
    If there is any air blockage installed. check it if it can work fine for time to come otherwise replace it with same one.
    after that open (free up) the bolt on "T" attached in between CNG regulator and Air intake entry point.
    Now accelerate your car at a constant high RPM and tight up the main screw on T. u will fine out a point where engine starts to crumple because of reduced gas flow. Adjust the position as per your prefernece. (ensure optimum flow of gas)
    after that adjust idling (no tool needed in case of landi ranzo)
    adjust as per you liking.
    This is CNG tuning, plugs and air cleaner inspection is mandatory in any tuning also Distributor point (if any)
    u r done
    Keep a cool head and wear seatbelts!
    2fastnfurious's Avatar
    Oct 2005
    Rawalpindi
    38
    313
    Quite deeeply explained by our freind sepctra...
    wither u can do it ur self or can take it to the ENERCON 4 computerised tuning as there is no match of mannual adjustment as compared with computerised tuining...
    Race lani Jay ....:-)
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @Spectra
    So finally you disclosed the trick you were hiding from people.....
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    spectra's Avatar
    Jul 2005
    40
    19,658
    299 Post(s)
    22 Thread(s)
    no trick brother
    this is standard procedure.
    Its just the neeyat and honesty with which u do the settings
    Most mechanics make sure that customer comes back 3 4 times for small money.
    Otherwise no trick involved anywhere.
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    (y)
    Adnan's
    Gulsher's Avatar
    Dec 2005
    66
    38
    Gentlemen
    Thanks for replying
    I actually had lost track of the thread
    The person who installed the kit in my car does not ask for moneyand periodically he cheerfully does the setting. i asked for two reasons:
    1. It seemed a simple think
    2. On the road for any reason if one does not like the performance of the car, one may like to tinker a little until access to workshop becomes possible.
    Anyway Thanks a lot.....any more input will be welcome
    spectra's Avatar
    Jul 2005
    40
    19,658
    299 Post(s)
    22 Thread(s)
    es Gulsher u r rabsolutely right
    Considering different pressure and quality of gas at various places.
    This skill comes in handy when u r travelling long distances.
    SER_GTR's Avatar
    Nov 2005
    30
    9,696
    14
    477 Post(s)
    19 Thread(s)
    hello!
    nice spectra bhai.....its all i do when i am tuning up..... be also tell them to have 21mm plug socket ,one connecting rod and rachet....open up the plugs.....get them cleaned...cost rs 10 ......adjust gap.....and them with slow hand tightened uo the plugs....don't tighnten much bcz they to much tight plugs can cause problem in next time opening...bcz they heated and casted iron expand till some extend.....
    also rotate idle knob clockwise to check up for best idle flow oif gas...clockwise decrease it while anti-clockwise increases it.....
    done....
    clean air filter from pressure air weekly......
    no way your cars can't give max milage on CNG...
    Thanxxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    devilhimselff's Avatar
    Apr 2006
    Muscat
    43
    104
    @spectra.
    Please can you tell what the 2 screws do. I mean Idling ? and the other one that you explained (air intake) ?
    What about the CNG Consumption, does fiddling these two screws adjust that too.
    I have a LR kit, and want to race the car up a bit when AC is turned on, how to do it, and will it effect average. One screw is at the top of the kit and the other one at side.
  12. #12
    bilal49er's Avatar
    Jan 2005
    Hyderabad
    40
    1,542
    read the reply by SPECTRA...its comprehensively covered...
    then have a look at my diagram for explanation / clarification..for further help call me anytime on 0321-5181108
    CNG TUNING How to do it -642035
    sent from my HD2 without using the handset itself!!
  13. #13
    Apr 2006
    Muscat
    43
    104
    Thanks Bilal for the Full Picture.
    Well I am totally "vaila" when it comes to cars, Ive been learning little by little since I joined Pakwheels
    Anyways the thing that I wanted to ask was what is "idle" setting, is it when the car is start and at rest ?
    and what is Peak Speed Adjustment, when the car is at High speed ?
    And what setting is responsible for cars CNG Consumption.
    Thanks again.
    Think I am gonna take Panga with my CNG Setting
  14. #14
    Apr 2006
    Muscat
    43
    104
    Well ?
  15. #15
    spectra's Avatar
    Jul 2005
    40
    19,658
    299 Post(s)
    22 Thread(s)
    Peak speed adjustment is responsible mainly for consumption. clockwise rotation decreases gas flow and anti clockwise Increases gas flow
    Idling/mixing is responsible for engine apeed at idle. if u feel load with AC adjust where u think it is suitable.
  16. #16
    Alcapone's Avatar
    Jan 2005
    39
    752
    2 Post(s)
    tuning CNG is tricky, takes time and sweat!
    According to my experience, either u could go for economy or performance.
    set the idling, and i got the best results for performance if u nail the throtle all the way down immediately after a u turn in second gear or goin uphill under 2000 RPM. i used to do this on ma way up the hills. u can rotate the CNG main screw clockwise or anti clock wise to ge the max output.
    Life is about passion...not fashion!
  17. #17
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    I think set your car on optimum performance and then learn how to drive the car economically.
    Adnan's
  18. #18
    AbidSiddiqui's Avatar
    Oct 2005
    36
    2,791
    I think these experiments might cause engine some serious problems
    Moderators' attitude / role should be "live and let live", or, "post and let post", rather than "Close, Move and Delete the post"
  19. #19
    spectra's Avatar
    Jul 2005
    40
    19,658
    299 Post(s)
    22 Thread(s)
    testdriver has hit the jackpot here once again
  20. #20
    bilalahm's Avatar
    Jan 2004
    3,042
    22 Post(s)
    7 Thread(s)
    The little things that make the BIG difference ...............
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
