Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree1Likes
Thread: Bubbles in car radiator
    rashed's Avatar
    Aug 2009
    42
    Default Bubbles in car radiator
    Dear fellows, i need your expert advice.
    A few days ago i got my Suzuki cultus model 2004 head gasket replaced as car was overheating and bubbles were observed in radiator.
    Now after gasket replacement, there are still large bubbles occasionaly coming out in radiator. Although car is not overheating but after half an hour drive with AC on, the radiator water starts spilling in water bottle. Temp needle stays at normal position.
    What can the problem be now?
    scorpion80's Avatar
    May 2007
    35
    4,320
    11 Post(s)
    ok ...
    check your radiator condition as well as fan speed ..
    AsadGhumman's Avatar
    Jan 2009
    31
    2,378
    28 Post(s)
    19 Thread(s)
    First of all get your car's heat sensors checked. I don't think needle should remain at normal position if radiator is spilling water. Secondly, get the radiator cleaned thoroughly & check fan speed as well as mentioned by "scorpion80". You may need to install a relay if fan speed is slow.
    After cleaning the radiator, carefully watch that the mechanic is properly connecting the pipes & no pipe is un-duely pressed from somewhere... Mechanics often do such blunders to get rid of the task...
    I am sure these steps will either solve the problem or you will atleast identify the point of failure.
    rashed's Avatar
    Aug 2009
    42
    I yesterday cleaned the radiator with radiator flush but radiator condition is bad. Most of its fins are deshaped.
    My question is why bubbles are still appearing?
    Ghuncha's Avatar
    Aug 2005
    34
    5,966
    19 Post(s)
    i still think you have compression loss through head gaskit
    its all about power to weight ratio...
    Jan 2009
    31
    2,378
    28 Post(s)
    19 Thread(s)
    Quote Originally Posted by rashed View Post
    Radiator flush is useless... Go to workshop & get it cleaned properly. I think this will solve ur problem
    haroon_1's Avatar
    Dec 2010
    24
    1,584
    27 Post(s)
    coz their is no thermostat valve in your car! it has been removed
    rashed's Avatar
    Aug 2009
    42
    Quote Originally Posted by haroon_1 View Post
    sorry i could not get you? Do u mean that due to absence of thermostat valve, the bubbles are coming?
    Newbie Follow
    BikeJunkee's Avatar
    May 2011
    Leave the engine running @ roughly around 1500 RPM and keep it there for 30 to 40 seconds with the radiator cap removed, Then check if there are still bubbles coming out. If yes then there is a probability that there is corrosion in the engine head or engine block around the piston rings.
    haroon_1's Avatar
    Dec 2010
    24
    1,584
    27 Post(s)
    usually mechanic removes the thermostat valve after replacing head gaskit e.t.c! this is done to keep temperature colder! if dere is no overheating and reduction of water then all is normal. your problem is not a problem this all is due to the removed thermostat. if water is not reducing and car is not overheating then it is normal dun worry!
    when the valve is removed the water circulates the whole water body freely due to this the bubbles are produced.
    i think this will help u!
    regards!
    rashed's Avatar
    Aug 2009
    42
    regards!
    sounds good, thanks
  12. #12
    rashed's Avatar
    Aug 2009
    42
    Today evening, i am going to my mechanic for a thorough check. I shall update tomorrow morning.
  13. #13
    rashed's Avatar
    Aug 2009
    42
    Yesterday, i got my car checked from Khan Autos(Faisal Khan). First its temp sensor was checked which was ok. Although it was assured that gasket was not leak, even then head bolts tightened a bit. Bubbles are still present in radiator but no overheating issue.
    Let's hope for the best.
  14. #14
    talhawaleed's Avatar
    May 2009
    1,779
    109 Post(s)
    2 Thread(s)
    Bubbles in Radiator is always an indication of head Gas Kit failure. I believe that your mechanic has not done it right. Recently I have experience slight bubbles in Radiator of Honda City 2007, I took the car to multiple mechanics and all of them said that it does not matter as intensity is low. I had this thought in mind that are they really qualified enough as they are providing such a careless verdict and not trying to point out the reason for these bubbles. Eventually a mechanic agreed with me that it’s a headgaskit failure but I can still drive my car but problem is bound to increase and will put you in trouble very soon and will eventually can damage the engine. In simple words their diagnostic skills are very week because they have never read a book and all they have learnt is through their USTADS. They know how to open the Headgaskit and replace this but in simple words they wont be able to diagnose well.
    Eventually I went for a headgastkit replacement immediately and later mechanic showed me the burnt headgaskit and it was in miserable condition and he appreciated the fact that I took the action on time.
    Brother let me narrate you a second incident that I went to Lahore on Corolla 2007 whose Radiator busted in Liberty market. I would not go into detail but this it all happened because of my mistake of using Acids on the radiator for cleaning. The wise thing I did once the temperature went to red was that I parked the car on road side as this happened instantly and waited for the engine to cool down and then once it was cold again I started the car and poured the water into the radiator and took the car to the Radiator guy to correct the leakage. Once leakage was corrected then he poured the water inside the radiator and I started the car. Bubbles were coming out from the radiator. I was afraid in the start but later it stopped. This was because of a vacuum in the engine area not a problem with headgaskit. So vacume is suppose to disappear within 2-3 minutes and any thing after that is an indication of Headgaskit failure.
  15. #15
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,267
    19 Post(s)
    3 Thread(s)
    im guessing you are using plain water in the radiator. flush it out and pour in two bottles of radiator coolant eg. osaka green coloured coolant.
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
  16. #16
    brownrose78's Avatar
    Aug 2006
    1,453
    10
    5 Post(s)
    ideally there should be no bubble.
    Patriotism is when love of your own people comes first; nationalism, when hate for people other than your own comes first.
  17. #17
    capsat's Avatar
    Apr 2006
    Select City
    9
    11,600
    23
    11
    874 Post(s)
    15 Thread(s)
    swap the radiator from Bilal gunj if the fins are deshaped and engine corrosion has clogged the tubes, use coolant when you replace the radiator. It is just like Lungs for the car faster & cooler the circulating water better the performance.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  18. #18
    rashed's Avatar
    Aug 2009
    42
    yesterday put DK coolent in radiator and bled it thoroughly. Apparently there are no bubbles now but keeping it under observation. Tomorrow i will be on long tour and if there is any problem it will be probably highlighted.
  19. #19
    Aug 2006
    1,453
    10
    5 Post(s)
    rashed
    so is it ok now
  20. #20
    NashTrooper's Avatar
    Sep 2012
    4,237
    84 Post(s)
    14 Thread(s)
    Gaskit problem nothing else!!!
    The Bug.. that never gets thirsty...
Similar Threads
  1. bubbles in radiator of charade
    By mrgenius in forum Charade
    Last Post: 30-04-2011, 12:22 AM
  2. Bubbles in Radiator....
    By luckyaahmed in forum Mechanical/Electrical
    Last Post: 16-03-2011, 01:40 PM
  3. Bubbles in radiator Mehran
    By Ishtiaq778 in forum Mehran
    Last Post: 16-02-2010, 12:45 AM
  4. radiator bht kam bubbles bna reha ha
    By haroonthevirus in forum In-Car Entertainment (ICE)
    Last Post: 29-09-2008, 07:14 AM
  5. Bubbles in Radiator
    By BigNate in forum Cars
    Last Post: 06-09-2006, 05:06 PM
