Rs. 1200/4L
CanI mix Zic Super A with Suzuki LLC (Green) Coolant. Both are ethylene Glycol based. But I'm still fearing.
how much to use in a Cultus? and if using Zic, should i only use the coolant or need to mix water also?
How is the NASA Coolant?
Nasa is not good. Go for only Caltex Coolant.
Whats the price of caltax coolant? Is it a premix or requires reconstitution with water?
Caltex 1 L will cost you around 800 RS. Its not premix.
Not a premix..........then whats the formula/ percentage with water?
Go for liqui moly
Price, availability, constitution ?
"Go for liqui moly"
what is price of liqui moly coolant brother
and in which packing size it is available
I use to do 50 50 mix but u may read the bottle for exact percentage.
Quality is very good.
Tapatalk 2
Not too expensive only 300rs per liter and is easily available in the market.it is blue in colour.use 50 percent water + 50 percent coolent
if one can not find distilled water then should go for premix ones. better use normal quality premixed instead of mixing tap water with best coolant.
Rs 400/l
salam bro..
i hv caltex coolant for my civic reborn 1 lit cost me 800. shud i mix normal tap water or distilled with 50/50
thanks
Caltex are selling 3 qualities of coolant which costing 1. Rs, 350 2 Rs. 8003 Rs. 900which is recommendable for Cultus Car.please reply on under mentioned address:msik63@gmail.com
Use Guard Coolant of Red colour.Even after this if your car get hot than you need to service or change your radiator.
