Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree4Likes
Thread: Nissan GA15DE Problem
    Mansoor1988's Avatar
    Jul 2012
    53
    Default Nissan GA15DE Problem
    Hello everyone, I swapped a GA15DE in my 1987 Nissan B12 Chassis. It has been over a year now, the engine was running fine without problems until now.
    Following are the problems that i am facing:
    1: I feel that the engine has lost it's power, what could be the main reason behind that? Could it be a clutch plate issue or an electrical problem ?
    2: The gear ratios are short. Is this normal ? I Usually change to the 5th gear somewhere around 80-90 K mph
    3: One of the axel has been welded because i could not find an exact fit. What can be done to get rid of the weld? any possible solution?
    I would like to ask all experts to give their opinions and help me out. Thanks.
    Jul 2012
    53
    22 Views and none replied. Where is everybody ??
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    33
    1,463
    34 Post(s)
    Your respective answers:
    1. First of all if you are running your vehicle on CNG then do check for spark plugs and ignition coil etc. If they are ok then go for any mechanical check (e.g, tappet adjustment, clutch plate, pressure plate etc.).
    2. If you change your 5th gear at 80-90, then its a good practice...u get fuel economy in early shifts.
    3. Purchase a kabli axle and fit it in because welded one adds risk to ur ride.
    I hope this helps u find ur problems and their solutions. If not then wait for more opinions.
    wasilrkhan's Avatar
    Dec 2007
    27
    467
    Quote Originally Posted by Mansoor1988 View Post
    at what RPM do you change to fifth at these speeds
    Never give up, never back down, Always give a 110 percent,
    NaXuN's Avatar
    Apr 2008
    5,468
    13 Post(s)
    Quote Originally Posted by AmeerUsman View Post
    no tappet adjustment in twin cam engines..!
    The Flag is the Embodiment, not of Sentiment, but of History.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    33
    1,463
    34 Post(s)
    Sorry bhai. Pardon my ignorance.
    SER_GTR's Avatar
    Nov 2005
    29
    9,343
    9
    418 Post(s)
    14 Thread(s)
    Mention Fuel Type?
    How You Get Its Wiring Done..Its Efi Engine ..So There Are Sensors Involved...!
    Did You Feel Power Drop Or Clutch Slip While Driving On Incline Areas.....!
    Gearbox Is GA15DE's Own Or From Your OLD Engine???
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    Jul 2012
    53
    Thanks sir, the tappets are not adjustable and the clutch and pressure plate seems to be working fine. I cant find the exact fit of the Kabli axel because the engine has been replaced.
    Jul 2012
    53
    Quote Originally Posted by wasilrkhan View Post
    Dont have an rpm meter installed. So not sure about it :p
    Jul 2012
    53
    Quote Originally Posted by SER_GTR View Post
    Mention Fuel Type?
    The car has cng installed and the problem persists on both fuels. The wiring was done from Bilal Ganj Lahore last year and has been working flawlessly until now. I bought the engine with it's original gearbox and the clutch plate never slips. I think some sensor is messed up, but which one?
    star2's Avatar
    Oct 2006
    30
    3,260
    244 Post(s)
    8 Thread(s)
    get throttle body serviced, and post a picture of the engine bay if possible......
    success is the ability to go from one failure to the next without any loss of enthusiasm
  12. #12
    SER_GTR's Avatar
    Nov 2005
    29
    9,343
    9
    418 Post(s)
    14 Thread(s)
    Check MAF Sensor And Clean..
    CHeck TPS Sensor
    Clean And Service TB
  13. #13
    SER_GTR's Avatar
    Nov 2005
    29
    9,343
    9
    418 Post(s)
    14 Thread(s)
    Better Check By Retrieve CODES....You Have CEL(Check Engine Light) Connected?
  14. #14
    Jul 2012
    53
    Quote Originally Posted by star2 View Post
    I will definitely get the throttle body serviced and let you know. I was going through your thread about your swap in your B13. Wanted to ask you about the axle rods. Were they a perfect fit ? will post pictures soon..
  15. #15
    Jul 2012
    53
    Yes the CEL is connected and i will check and clean the sensors you mentioned in your previous post. Thanks
  16. #16
    Proverbial_Slang's Avatar
    May 2005
    3,737
    26 Post(s)
    Was the loss in power sudden or you started feeling it over a period of time? What mileage have you clocked on the engine?
    The axles should be readily available in Bilal Gunj and even Montgomery road. This engine is not too rare.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  17. #17
    Jul 2012
    53
    Quote Originally Posted by Proverbial_Slang View Post
    Yes kind of sudden. Dont actually know about the mileage. Been a year now and my daily travelling on an average is around 40-50 Km so you can do the math .. I will get the throttle body serviced and all the sensors checked and clean and then report.
  18. #18
    djrizwanulhaq's Avatar
    Jul 2011
    Default Nissan B12 upgraded cooling fan installation help
    Hi. I have been looking for someone who understands Nissan twin cam engines. since its rare and mechanics are not reliable. so thought of signing up here and ask you for assistance.
    I upgraded my 87 sunny from E13 to GA15DE last year. Upgraded my radiator and fans with some newer version aswell. Now it has got 4 wires coming out of each fan with a 4 pin connector. One fan is connected with the a/c. the other one operates directly. the radiator fan assembly has no thermostat or any place to install it. Now winters are about to come. Engines stays cold almost all the time, resulting rpm to stay high since engine is unable to reach the reasonable temperature. Im sure youre getting my point. Rpm has no other idling issues on A/C as i have managed to get the IACV wired. Fuel consumption is good. sensors are working fine. Just want a proper solution for cooling system. I want one fan to be controlled by ECU. The other one only switches on when A/C is turned on. the other operates and needs to be wired correctly. please help me with this. How can i connect or control that fan to work automatically so it could only turn on whenever required and works with both high or low speeds. I got complete wiring with the engine which includes fuse boxes and relays. but didnt install that. ECU wiring has no alteration and installed the way it is. car has its stock fuse box and relays working. How can i make the fan work with the ECU? Or is there any other alternate way to get the fan operated automatically. I would really appreciate if you could help me out with this. I have already wasted alot on local mechanics and they dont know **** about how ECU and sensors work.
    Thank you
  19. #19
    capsat's Avatar
    Apr 2006
    Select City
    9
    11,600
    23
    11
    874 Post(s)
    15 Thread(s)
    me <--- click
    you may send a message to members hameed01 / ser_gtr / argtr / rustam & THE Guru - Xulfiqar
    - my suggestion is get a thermostat valve into the car cooling system, Thermostat valve is an item installed inside the engine. The red circle is approx position for thermostat valve. 4 wires are standard for cooling fans, to work on high & low speed with & without aircon. Use suitable coolant prepared in bottled water with 60% water -40% coolant ratio when you flush engine after placing thermostat valve into the system
    Nissan GA15DE Problem -1290411
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  20. #20
    spectra's Avatar
    Jul 2005
    39
    19,652
    290 Post(s)
    22 Thread(s)
    clean the water temperature sensor as well. it is an important input. Also engine should have thermostat in it.
    Keep a cool head and wear seatbelts!
Similar Threads
  1. Nissan GA15DE ECU Wiring Help
    By star2 in forum Nissan/Datsun
    Last Post: 23-01-2016, 01:16 PM
  2. SER_GTR's Nissan B13 GA15DS Swap.
    By SER_GTR in forum D.I.Y Projects
    Last Post: 20-01-2016, 08:46 PM
  3. Installation & Functions of Advancer/Emulator
    By irfan44 in forum Mechanical/Electrical
    Last Post: 06-06-2015, 04:55 PM
  4. Replies: 18
    Last Post: 23-08-2012, 11:57 PM
