Results 1 to 9 of 9
Thread: engine shuts off on low rpm and rpm drops (100-200rpms) at idle rpm.
    kami_shah's Avatar
    Apr 2009
    32
    17
    Default engine shuts off on low rpm and rpm drops (100-200rpms) at idle rpm.
    AOA, brothers ... I ve two different problems facing in my toyota corolla xli 2010..
    1. Engine tries to cuts off at low rpm when i go slow in 1st or 2nd gear for speedbreaker
    2. Rpm shows a drop of 100 to 200rpms when engine is running at idle rpm, however constant idle rpm is 800
    moreover i want to know at what rpm my car should touch 120km in 5th gear...
    Early advice is expected from experts as i am planning to take my car to mechanic on coming weekend...THANKS
    kami_shah's Avatar
    Apr 2009
    32
    17
    no advice ????
    wasilrkhan's Avatar
    Dec 2007
    28
    515
    Most probably throttle body needs a service.
    Experts kidher hoo....
    Never give up, never back down, Always give a 110 percent,
    Bilalch_88's Avatar
    Dec 2012
    Sadiqabad
    29
    Quote Originally Posted by kami_shah View Post
    bro r u driving ur car on CNG???
    argtr65's Avatar
    Dec 2008
    50
    1,606
    68 Post(s)
    7 Thread(s)
    are you driving your car on cng?
    Never loose hope in life,every step gives u something.
    kami_shah's Avatar
    Apr 2009
    32
    17
    nope . .. brother i m driving it on petrol..
    argtr65's Avatar
    Dec 2008
    50
    1,606
    68 Post(s)
    7 Thread(s)
    Replace fuel filter and get the fuel rail & injector cleaned.
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,093
    5
    183 Post(s)
    11 Thread(s)
    can be grounding issues as well,any dimming of lights when using power windows etc?
    www.facebook.com/performancepartslahore
    ngen's Avatar
    Oct 2008
    37
    166
    Erratic Idling - Get the throttle body washed/cleaned. Make sure they use Carb cleaner and not Petrol.
