3 Service Tips for Maintaining Your Honda Civic
A s a smart Honda Civic owner, you understand the importance of maintaining the value of your car, and you care about making intelligent decisions that will maximize its long-term performance.
Here are a few of our tips for truly keeping your Honda Civic in strong working order:
1. Transmission Fluid - Anyone who knows what it?s like to to replace a transmission, or drive with an irregular, irritated transmission, will tell you that transmission fluid is a vital ingredient to your car?s success and performance.
The fluid in an automatic transmission impacts how well the transmission shifts, how smoothly it transitions, and the overall durability of the transmission.
oil
Furthermore, this single ingredient can increase your Civic?s fuel economy, and in the process, save you money at the pump.
Over the last five decades, Honda has laboratory-tested a specific formulation for Hondas, composed of the finest ingredients. It?s called Honda Genuine Automatic Transmission Fluid. It?s the gold-standard of transmission fluid for your Civic. It exists to serve your need for maximum performance and efficiency.
2. Fuel Injector Flush - Did you know that clean fuel injectors can mean the difference between peak engine performance and, on the flip side, a damaged engine that costs more to operate?
Essentially, fuel injectors are what push, or rather spray, your gasoline into your engine?s combustion area. A fuel injector flush is the process of cleaning the injectors themselves for proper operation.
Efficient fuel spray means saving you from wasted gas expenses while also preserving a healthy engine. A fuel injector flush can also see to it that dirt and particles aren't floating around inside of your Honda Civic?s engine areas. It?s a win-win, because in the process you improve your vehicle?s performance and help improve your gas mileage.
3. Full-service Oil Change - Think about the last time you were dehydrated from a lack of water. Didn't you find yourself irritable and less-energetic? Do you remember feeling fatigued quickly?
That?s similar feeling to what you?re putting your engine through when you don?t support its performance with the proper motor oil fluids. Your engine operates sub-optimally and its performance deteriorates as a result of using fluids which are not Genuine..
Motor oil protects the moving parts in your engine in order to ensure your Honda is running at maximum efficiency. Like water to the human body, motor oil keeps your car?s engine energetic, flushed clean and running smoothly.
In addition to up to 5 quarts of new, premium Genuine Motor Oil, a full service oil change includes a new good Oil Filter. Don?t overlook the importance of quality assurance when it comes to the oil entering your engine -- your car?s oil filter strains out impurities and contaminants before they flow into the engine and potentially cause harm.
Think of your oil filter as part of your car?s immune system that screens out potential harmful bacteria and disease.
Simply stated, you need a good-working oil filter to maximize your engine?s life.
