I want to ask from expert ,can speedometer be repire as it is showing less speed than actual.It was opened by someone to change leds.
Yes you can but it depends upon the availability of the speedometer in the market
Sorry I thought you were asking about replacing, well it can be repaired but you never know it works as it was before you changed the LEDs, so better option would be replacing the speedometer
thanks for reply.will open it by myself.
Better buy a new meter or just replace the machine inside it...repair rarely works
Sent from my SGH-T989 using Tapatalk
If the needle was moved by the person who opened it, and you think its showing slower speed, then at really slow speed the needle is at Zero "0" km/h?
my bolan meter had the same issue after adding leds and changing needles the meter can b adjusted by moving the spring inside the meter i calibrated it with gps and is now showing accurate speed
Yes bro i did the same thing and it is working perfect.
