Experts here the the car in question is Honda City 2012 with mileage 35000 only, one hand driven only. The problem is the hard clutch pedal. Whenever i stuck in traffic block i literally have pain in my foot by pressing clutch pedal again and again. The clutch pedal is hard to press and i have shown it to different mechanics. Some says its due to bad pressure plate, some says it is due to bad master/slave cylinder and even some says its just fine. I went to mechanic who said that it is due to pressure problem for clutch pressure plate replacement but he did not open it as he was not sure because car is only 35k driven and excellent condition never drive with foot on pedal. Car can have a wheel spin even in 2nd gear too. Now i have a option to go for master/slave cylinder check but there is no symptom of faulty master/slave cylinder.
Experts please help me in this regard. Here is information which can help you to advice me.
1) Car can have wheel spin even in 2nd gear, i recently went to Naran and did not face any problem regarding uphill drive or gear changing.
2) One mechanic diagnosed that rubber pipe connecting the line between master and slave cylinder is blocked, he changed it but problem of hard clutch pedal not solved
3) I was also feeling a little problem of hard shift, but after bleeding clutch the problem resolved and also clutch hardness reduced almost 10%.
4) I never ever roasted its clutch by racing/ drag or by keeping foot continuously on clutch pedal. I always used foot rest.
5) There is no leakage, no oil reduction.
6) Working of clutch is fine no any problem except hardness.
Please suggest me what should i do??? How to get rid of this problem.
One more thing, i have drive my friends same Honda City car but that has so much soft pedal. Even my cultus has so soft pedal.
Thread once started cannot be deleted until conditioned, but can be closed. Let us know when ever you like to open it - MOD
