the company lists 8 points to check on the techincal section on its website to see if the pump has been abused it passes all of them except one which is the presence of flat hit marks on top and bottom corners. otherwsie its fine, the other points are
something to do with bell housing area
broekn base or missing corners
side trap damaged
sight glass shows buildup
handle bent down or broken
intake damaged or missing
it passes all of it except the flat hit marks on the corners. rest i will fill it up and run it tomorrow, it takes 110V and i would probably need a heavy duty convertor and watts are not present and has a 1/2 hp motor so it may fry regular 220/110V convertors.
