fool a.c wala ask me to change it's magnet as it's inner edges are destroyed and this is the only way you can have it back in working. so i agree to change it's magnet but magnet was not from it's original compressor it was from Shehzor i think. while fitting a/c wala guy's boy broke pipe line of a/c they the senior guy try to fixed it. every thing goes fine that time. but after 1 month a/c reduces it's performance and in 2 and half months it becomes like when i throttle the pedal it makes room cool other wise like only fan is running. i went to the guy from where from it all was done. he said k you have to change compressor and everything including. lum/sum budget 16k for all things with labour.
two days ago water pump start leakage without any cause car was fine few hours ago and when i switch on the engine it was showing heat gauge start raising in still position of car. so i went for water body change. all process done. start the car and after few mins i hit the a.c button but compressor was not running.
electrician's chootu said compressor is gone because it's not even moving on direct connection from battery.
A/c wala said k bhai u have to change compressor and only 2.0 D compressor is mandatory for this model.
i was searching in forum regarding the matter and read some posts of Xulfiqar if the gas is finished compressor wont start.
so this is the problem i'm looking for it's solution. If anybody can help me in this matter i will be very thankful to him.
