2E is probably 75 hp engine..
bhai that is not correct.
2E with power steering was barely pumping out 58 hp without rotary type a/c compressor
the cars without powersteering ran better on 2E.
2ndly the decision depends on yr budget and luck to find a clean engine,, there are lot of engines for sale,, get the 1 which has some warranty by seller, and spare parts avaliable.
after budget,, comes yr requirement, if you find yr car underpowered go for bigger engine than you have.
and last , efi engines like 4afe run better on cng than 2e,, if cng concerns you.
