Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 95
Like Tree1Likes
Thread: 4A-GE 20V Powered EP71 Starlet........!!
    SER_GTR's Avatar
    Nov 2005
    29
    9,670
    11
    458 Post(s)
    18 Thread(s)
    Default 4A-GE 20V Powered EP71 Starlet........!!
    Hello!
    well.......due to lack of 4AGE 16V engine......as i won't find any....i am thinking of switching from 4AGE 16V to 4AGE 20V in EP71.....well here's one clean transplant pics i am posting........!4AGE 20V ST into EP71.......!!
    i think 4AGE 20V can fit in EP with not much problem......!
    see the pics......car was moded in Malaysia....how clean setup....! all stock with just air filter changed...
    what do you ppl say.....is that fine to think over that kinda transplant......!!
    20V in EP71...!! does it make a good combination?
    Replys needed...!
    well here are the pics..
    4A-GE 20V Powered EP71 Starlet!! -489134
    4A-GE 20V Powered EP71 Starlet!! -489135
    4A-GE 20V Powered EP71 Starlet!! -489136
    Thanxxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  2. #41
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    if you cant do it yrself, ask racerf1 to swap 1 in dubai, and send that to you. there are better starlets lying around in dubai than you can find here.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  3. #42
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    @SER-GTR
    the suspension parts are the same too in both e81 and e80. So all drivetrain parts are interchangable. Wish you good luck in finding a clean car
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
  4. #43
    spectra's Avatar
    Jul 2005
    40
    19,658
    296 Post(s)
    22 Thread(s)
    @levin he is on a budget
    Keep a cool head and wear seatbelts!
  5. #44
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    well, he can always ask for a discount.... weather he gets it or not that's another issue.
  6. #45
    NoS_1's Avatar
    Jun 2005
    Peshawar
    26
    1,044
    What abt 20v in 94-95 civic Levin bhai?
    Don't underestimate SOHCS!!!
  7. #46
    Starlet_GT's Avatar
    Jul 2005
    41
    1,438
    @Levin
    Its not that easy to buy a car in dubai and then import it ... its better to buy a AE-111 with stock 6 speed BT and import it directly in Pakistan ... Modified cars always causes problems ...
    Well this swap will definatly a BT ...
    Power is "NOTHING" without "CONTROL"
  8. #47
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    nos-1 :
    b16 or b18 is ideal fit for civic not a 20v.,,,,, toyota 20v engine is opposite of Honda b18,, gearbox on opposite side,, design and location of mounts is diffirent,,, and 1 guy did try this,, he swaped a 20v in civic95 and drove around,, but it wasnt an easy 1.. lot of alignment required and mechanic did it because to mechanic that meant $.
    starletGT:
    . that was only a suggestion, Alta can answer better,, i never imported a car before ,,,i agree swap sounds practical
  9. #48
    Starlet_GT's Avatar
    Jul 2005
    41
    1,438
    @Farrukh bhai ...
    You have taken a wise decision ... although ever thing is possiable but takes a lot of time and $$$
    Sprinter is a good car for a BT and will give a good performance ... if you have a big saving after this swap you can buy a turbo kit of HKS for your BT ... and smoke every one ...
    Who said swapping 20v in EP71 is not possible ... ?
    Look a guy swapped 4A-GZE in his EP 71 ...
    4A-GE 20V Powered EP71 Starlet!! -684856
    Look at this clean 3S-GTE swap in EP 71
    4A-GE 20V Powered EP71 Starlet!! -684857
    These guys done a lot of hard work and spent a big time + many $$$ ... that why they dont recommend others to do the same ...
  10. #49
    palaykhan's Avatar
    Jan 2006
    Peshawar
    28
    7,378
    ooooffff 3sgte EP 71 man its going to fly...
    my rides.....!!!.AE90 4AFE supercharged nitrous.........!!!.http://www.youtube.com/watch?v=IhNhlNoYq8s......!!!civic 3g hatch B20 almotor nitrous............!!!intgera B18b LS Vtec nitrous
  11. #50
    SER_GTR's Avatar
    Nov 2005
    29
    9,670
    11
    458 Post(s)
    18 Thread(s)
    Hello!
    @Levin Bhai......!
    thanxx for sugession but i wanna do this myself all the workout.....if i just wanna drive a good car....why i buy starlet and put 20v....i better buy an fresh imported Ep82 with 4EFTE moded or any new model Sprinter with 20V......!!!!!!!having all Genuine 4AGE equipments..along with LSD..
    @Starlet.....iBrahim bhai.....Impossible is not in my dictionary... but difficulty is what i have to face.....! EP71 was among one of the cars which came in my mind when comes to project car........but the motor is somehow difficult to manage in that on which i can't compromise..then suspension issues...drive axles making engine place was another...so i won't wanna be in such tension that my hommies will ask me to leave that all including home ...........so thats why i take a decision and shifted on Sprinter.......!well on sprinter...i am free......i have many options in every expect... suspension..a diesel one can help me......and what not....free engine room good space...brakes...engine also looks not like it was fitted hardly....!also a balanced car was another good factor....!so all i am doing now....tickmarks on Classified and checking demands......one ad is from your area......maybe INSHALLAH soon i will find a nice clean Sprinter.....!
    Todays...rain spoils all thing.......reached home in 3 hours from 2'ft deep water on roads........
    well i don't know but when i decided to buy a 20V and sprinter.....i am getting what i am looking earlier.....!
    4AGE 16V was found by someperson in shershah.... demand a/c to him 24k......don't know what he watch but i tell him the name.......another 16V was found in lahore by MR Mudassar....he have had 2 non TVIS .........!
    aahh.......! what a luck i have........totally disbalanced..
    Thanxxx
  12. #51
    Starlet_GT's Avatar
    Jul 2005
    41
    1,438
    @SER Farrukh bhai
    try to find a good sprinter and keep following things in your mind while looking for a car ...
    1. ruined engine (prefered)
    2. needs paid job (but not rusted)
    3. shocks should be in good state
    4. interior should be neet and clean
    5. prefer with alloys 15"
    Best of luck
  13. #52
    NoS_1's Avatar
    Jun 2005
    Peshawar
    26
    1,044
    @levin
    Hmmm,Well I was thinking of a 20v swap cuz they r readily available in shoba bazaar and the swap is quite popular so mechanics can do it properly,hmmm,then in which model of corolla would u say the 20v fit perfectly and work best in?88-90 or 92-95(Jdm or 95-2002 PDM)And how much would a complete b16a and b18c swap cost(including tranny ecu etc)and will the mechanics here in pesh be able do it properly?
  14. #53
    ahsan1702's Avatar
    Mar 2006
    27
    4,023
    SER_GTR bahi ... I have had in my mind a 4AGE 20v BT in a Sprinter for a long time.
    So naturally I have looked up the prices for a Sprinter. A good working one with CNG costs 2,25,000 on the asking price. You can make the buyer sell it for 2 lakh as Sprinter doesnt sell that good. For 2 Lakh even with CNG, you can sell the CNG kit and the engine and tranny then get the BT.
    The BT would fit nicely in the Sprinter.
    @nos1
    If you find a complete front cut 4AGE 20v ST from a Corolla GT then getting a 92-95 JDM Corolla is the best option. Everything will fit directly from the front cut and you will have your car to almost Corolla GT specs. Im sure BT will fit the same as well ...
    1st Generation Integration
  15. #54
    SER_GTR's Avatar
    Nov 2005
    29
    9,670
    11
    458 Post(s)
    18 Thread(s)
    Hello!
    @Starlet Bhai..........
    well thanx again for points...i will keep that in mind....but i think shocks need changing with 2.0D stiffer ones?? what u say....and check mail......!!
    @ahsan1702..............thanx for info...well man....what a coincidence...today i have checked a sprinter with 2,25,000/- price tag including CNG..(saw ad in sunday classified)..........
    it was near my home my chance.......car needs paint job....badly rusred doors....doors cardboards are all ruined...seats are ruined....and what not...well the damn thing...engine was strong as hell ....revs like hell even on CNG...i checked it 2 times and never find anything bad in it since i don't need it .....when starting car a sudden jerk....dashboard was vibrating alot...looks like one back mount have some problems....well car was badly ruined....and i never wan't car like that....!
    checked 3 sprinters.......1 i checked my self today....
    2 left.......and they have more demands than this...one was owned by a major... hope it will be a good in shape...
    Thanxxx
  16. #55
    muddy786's Avatar
    Nov 2006
    40
    92
    yar do u realy have ep71 if so tell me i am coming to karachi for 15 days i can help if u want for putting in a 20v b/t thats my promise .
  17. #56
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    hash: looks like 20v virus is back in full swing this winter..
    nos : bro,, muddy and palykhan from peshawer can answer better yr question about swaps in peshawer.
  18. #57
    ahsan1702's Avatar
    Mar 2006
    27
    4,023
    Lolz, achay piece bhe itnay main milaingey bro ... Ill post up here if I come across one.
    Yes levin bahi ... nothing like the note of individual throttling bodies ...
  19. #58
    muddy786's Avatar
    Nov 2006
    40
    92
    @nos bro maybe u r right but if u swap in psh u have to repeat every thing again acording to my experiance they dont do there work with heart for us they only do it for locals.
  20. #59
    hash4u's Avatar
    May 2005
    37
    23,968
    15
    374 Post(s)
    13 Thread(s)
    10
    LoL @ 20v Virus
    lets see how many are able to run with High Octane @65 rupees per ltr (6)
  21. #60
    Starlet_GT's Avatar
    Jul 2005
    41
    1,438
    @farrukh bro ...
    Shocks are not big deal ... I have seen shocks from AE-III which came along with BT and complete suspension along with foundations, ventilated disk brakes/pads etc.. etc ...
    but first assignment is to find a good car ... suspension is a secondry issue ...
    The virus of 20v is back but this time its not ST ... its BT
