khachar,
aawlla
They have covered the right side of the grill.How will the AC condenser of the VXR trim get air with this type of grill?
hmmm chlo kuch to change hua
Plenty of spaces. There is no cover under the engine and the openings through the bumper should suffice.
^ But still...It does not seems wise covering the major place for air in a car which already does not have a decent air conditioning system.
OMG OMG aaj woh din aa he gia suna to bohat tha k mehran efi a rahe ha but sun ker yakeen nahe aata tha finally a gae I know that mehran needs to be change completly but atleast fuel consumption to definitely much much improve hoga bcoz 800cc with efi should give max mileage on petrol ma to kehta hoon ab cng ko bye bye kehna chahye if it will be capable to give 18 to 20 kmpl. Brothers mujhe lagta ha k aab A/C will must work well in mehran bcoz of EFI engine what do u say am I right or wrong. Last thing very ugly front grill.
Form over Function! The condenser in a Mehran is on the left hand side and not the right hand side. The engine is on the right hand side. Just by the blocked off grill is the exhaust manifold and above it are the spark plugs. The reason it has a blocked grill on the RHS is to save the engine components from dust, water and grit. Try pressure washing the car and see what happens when water goes into the RHS part of that grill. It goes right into the spark plug slots and into the hot manifold. And that my friend, is not a pretty sight. The same blocked off grill concept can also be found in our local Altos. There is a reason why earlier Mehrans (1991-1998) have the old blocked off grilles
finally.....a dark era comes to an end...!!!
a good step
ab jaldi se EPS, 4wheel discs, driver and passenger side airbags, cruise control, brake assistance, ABS, climate control, air purifier, power windows and power mirrors de dain
Mehran's condenser is placed in the circled place in the attached pic:
Add Rain Sensor
basic engine is same as of the previous mehran...but intake manifold is changed...electric fuel motor is installed...i think its intake manifold system including ignition system resembles to 4AEFE OF 5AEFE engine of toyota which used to remain current in 86 to 2002 toyota models...isnt so?
I hope now it doesn't have that crappy point ignition system, as it was the most annoying part in that engine
kawwa chala hans ki chaal aur apni b bhool gya...i guess it will be available at more insane price !
Guys atleast Now we are EURO 2 compliant country, and finally Mehran is EFI means better pick and better fuel efficient car and AC will work fine since engine is EFI. I think we should be happy to have good change in 25 Years old shape car.
One think more that someone posted long time back that Suzuki sent her workers to india in order to learn EFI technology, so finally we have EFI engines and EFI Mehran engine is same as Indian Mehran engine please check on WEB Sites you will find.
For some reason, i get a feeling that this isn't real.. although i hope it turns out to be.
oh bhai its a good thing plugs are behind this covered surface and in rain u see many mehroo's stall some taxi walas put shoping bags in this place and this will stop water going in plugs
even in previous models...there is a metal sheet placed on the back of grill on left side (only original grills have it) which effectively makes the air passage blocked towards engine.....
