Not exactly what I said.
There is a chance, though more harm than good may come of it (especially if custom ROMs is/are tried)
For those interested, u can follow the Dell Official Update Process as listed below, and for more info, encourage to read through the entire thing:
Quote
Dell Update Process
Contents*[hide]*
1*Introduction2*Stock Update Process3*Update pkg Naming Scheme4*Version String Naming Scheme
Introduction
The OTA process for Dell devices is slightly different from normal OTA updates such as on Nexus devices.
On a Nexus or similar device with an update available the device downloads the latest update zip that contains the pieces required to update it to the lastest available version. On a Dell Android device it downloads an update pkg that is an update zip but in encrypted form.
Also on Dell devices, the roms are differentated by region, the decrypted update pkg will check to see that the current recovery region matches the update itself. So that you cannot install an update from a different region without reflashing your stock recovery.
A*fota mismatch*occurs when the recovery is from a different region then the update pkg, commonly caused by the user downloading the update manually. An example is trying to run a 00 region update (which would be a retail update) on a 31 region recovery device (which would be an At&t device)
(Assuming the device has a stock recovery installed)
Checks if there is an available update from DellDownloads the correct update pkgReboots into recovery modeDecrypt the update pkgRun the update pkgUpdate pkg checks to see if it is the correct deviceUpdate pkg checks to see if it is the correct regionIf both are true, begin update processIf installation completed sucessfully, rename decrypted copy to update.pkg.decUpdate pkg Naming Scheme
Update pkgs are named as thus (with exceptions):
DEVICE_VERSION_BUILDNUMBER_REGION.pkg
example: Thunder_408_20707_14.pkg
Is a: Dell Venue gingerbread rom, version 408, build number 20707 for region 14 (olleh kt)
Device:Streak*for the Streak 5LG7*for the Streak 7Gallo*for the Streak 10Thunder*for the VenueVersion:0xx: Android Various*Prototype Roms1xx: Android 1.6*Donut2xx: Android 2.1-update1*Eclair3xx: Android 2.2 - 2.2.2*Froyo4xx: Android 2.3.3*Gingerbread5xx: Android 3.1 - 3.2*HoneycombBuild number:Self-explanitoryRegion:00: RetailUnlocked11: Hong Kong*Unlocked12: Softbank13: Starhub*Unlocked14: Olleh15: China16: NTT com17: E MOBILE*Unlocked21: O230: Dell31: At&t32: Rogers33: T-Mobile34: Cincinnati Bell(?)51: Prototype Rom(?)99: China - YiVersion String Naming Scheme
The version string reported in about device is:
DEVICEVERSIONhardwareversionROMVERSIONromregion
example: GAUSB1A110100
Is a: Dell Streak with donut, version 101, region 00 (retail/unbranded)
Device:GAUSB*for the Streak 5GLUNB*for the Streak 7GALLO*for the Streak 10MILLM*for the Streak ProGTOUB*for the VenueGLEOS*for the Venue ProHardware Version:1A1for the Streak 5for the Streak 7 4Gfor the Streak 10for the Streak Profor the Venue1A2for the Streak 7 3G1A3for the Streak 7 Wifi1A4for the Venue Pro2A4for the Venue Pro
Unquote
