Can anyone share info or experience as I got osaka gas 2.4 kw heater two day earlier.. it smells like that of gas and when I look at back where filter grill is.. I can see flames of burning fire... is it normal or does it need repair
Return it asap. It does not work like that. No flames should be visible.
Thanks. . I thought of same as there should be no flame... my other heater 3.4 kw of paloma japan is doing well and there is absolutely no need of any warm stuff when it is on
Can this heater work even when Sui gas pressure is low?
Yes. It does
Sent from my SM-G900F
Just got mine, 2.4 kw, so far going good.
Sent from portable device.
Self editSent from portable device.
From where you got in Lahore. Please share price and specs.
Not from Lahore, got from Islamabad, price varies with model, capacity and condition. Got two heaters of 2.4 kw @5500 each, model is 2008, 2009 , looks like not abused, extermly satisfied.
I purchased a room heater radiator type from matro made by a local manufecturer2000 wattsStill under observation and in trial runningWill update the result
2.4 mean 2400 Watts, too much power consumption ??
2000 Watt, again too much ??
Well i agree 2000 watt is to muchI observed that if i run it continue it consume 1 unit per hourFor all night 12 unitsToday i will run it on 1300 watts and will ck the consumption....
[QUOTE=mfdarvesh;4635954]2.4 mean 2400 Watts, too much power consumption ??
Go through the thread, it's main energy source is natural gas, electricity only needs to run blower which is in my case 25 to 30 Watts, less than a tube light.
Got a JDM Hybrid blower few days ago It's of Tokyo Gas, working is good, using it with the Converter.However, need translation of the buttons as everything on them is in Japanese
Use "translate" available on play store.
I have an iPhone, not Android
OKThen what is meaning of 2.4 then ??
These are not gas electric heaters!They need electricity just for sensors to run because these are electronic heater , no electricity , no heater! I am using this heater , is is good , clean burning no smell , even small children can go near it !Electricity also runs its small fan! Safe to useCan also run on very minimum gas less then a stove requires i.e even when stoves do not light
They aren't as good as gas heaters.
^^but they are more safe and energy efficientnormally electricity consumed is less than 30 Watts
