So guys our Kenwood A.C 1 ton finally gave up after 3 years of serving. Now instead of getting it repaired again and again, we have decided to throw it out and install a new one. Now we have realized that 1 ton is not nor enough to cool the whole room so we r now going for 1.5 Ton. So now guys need your suggestions on the best A.C unit in the budget of 40-45k.Another issue is that i almost live near to the sea so rust is my homes best friend. This is the reason why our A.C unit died in 3 yrs so suggest something which can bear the Sea and some methods to protect them from moisture and Rust.Thanks in Advance.PS: if anyone needs a 1 ton Kenwood A.C pm me. The inner is in perfect working condition however the outer is weak.Selling it at a throwaway price
In above mentioned conditions I think you should look for Panasonic , Malaysia made, hopefully it will prove bit strong than Chinese. Look one with anti rust coating,
Sent from portable device.
Haier is serving us well for last 3 years. No troubles at all.
I was actually considering Dawlance.What Say?
Getting mixed reviews, Some say dawlance, Some say Haier,Some say Kenwood and some say gree , Ask the dealers and they say, sub ek jaise hain sirf naam ka farq hai Confused..
go for panasonic and ask ac wala to coat every thing with liquer spray you can get it from any hardware store
M using Dawlance from many years n not a single issue since ages.......but no idea about its current price.
I finally got gree 1 ton after much research. Bought it last week. Its the first Chinese at home after 5 Mitsubishi splits. So far impressed with quality and build. Lets see how it runs. Btw which 1.5 ton comes in ur budget. Gree 1.5 ton is 51000. And I am sure reputed brands would be even more then this.
You live near the sea so anything u buy will go bad in three years,buy a cheap ac dont go for an expensive one because in the end u would be changing it in three years time.Gree is a better choice but like kenwood it would go bad in three years time.When i lived in karachi near the sea we tried to spray paint the copper pipes but that only extended the life of the outer unit by 6months max...so three years is the life...you would have to eventually change it so buy cheap.
Very good advice. I would listen to this always. Bcz no matter what u do its going to happen. Try samsung also and ask them if they have non corrosive thing.
Bro my aunt have the same case about rust then a mechanic told us that he has a solution he sprayed the outer unit with a ceramic paint and he said it will double the life of the outer unit and it does really help and as invincible doc said go for the gree it's better then the rest
Haier and Gree are better than dawlance. You should opt between these two . . .
Current price is around 43k
Bro im getting Haier, Dawlance around 43k, U r right gree is around 51k
That is actually a pretty good idea, Almost set my Eyes on Dawlance or Haier, Both r around 43k,
Thanks for the advice, I'll surely get is sprayed with Ceramic paint, Confused between unit now, Gree is surely a better choice but getting out of my budget, Ill go and ask more about prices tomorrow
Bro if gree is out of budget then go straight for dawlance monogram series you will be ama zed by its throw and also its energy efficient too
I too liked it, the display and looks r attractive, So now i have short listed two, 1.Dawlance Monogram Series2.Haier Energy Saving Series.Gonna finalize it in a day or twoThanks bro
Out of both. Go for haier. Lk 12. Runs wow
bro you are always more then welcome and where are you planning to buy it
i recommend you to patiyala groung adjacent to mayo hospital hostals they are good in price almost whole sale rate
