Well bro i have got a lot of source with Appliances dealers so i will already be getting it cheaper at a whole sale rate . Would most probably be buying this Week In Sha Allah
Guys there is a bit change of plan here, Today i brought a an A.C technician to get my other A.Cs Serviced and also asked to check this one, According to him the inner unit is in Brand New State while the outer is toast so just change the outer and it will easily work for 1-2 more years, So now what should i do? Should i buy a new unit knowing that it will also die in the next 3 years or just change the outer of the present one?
Go for gree inverter 1.5 ton
Sent from my GT-I9105 using PW Forums mobile app
buy the outer unit only... coat every thing with epoxy water proof primer.
why no one discussing Acson?
also if getting new.. then buy inverter based ac with heater option.
dawlance is chinese stuff local assembled.
Inverter I did research. But its good when there is constant power supply. As when we have 12 hrs loadshedding in lahore then the inverter function basically dies. Bcz when the power comes then the compressor is going to attain 26degrees or whatever we set. And in doing so its going to maintain high amperage and by the time the amperage is going to fall bcz of inverter tech, our power supply is going to go again. So basically no use in my opinion. At least for lahore.
Would be changing the outer for now as buying a new ac is useless
karachi halat not so bad...
Oh. Then it might be okay in your case.
Although you never know when our government shifts the tables with every upcoming year alongwith its new policies.
Yes.. dealer ask... All r same...
