Community Forum Actions
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 278
Like Tree78Likes
Thread: Liqui Moly Ceratec
    Vaqas1's Avatar
    Nov 2004
    4,503
    7 Post(s)
    Default Liqui Moly Ceratec
    Any experiance with this product?
    Available for 2000Rs
    Cera Tec - Oil Treatments by Liqui Moly
    CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines
    Basharatu, nomi700 and Skill like this.
    Speed costs money, how fast can you afford to go.
  2. #241
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    Quote Originally Posted by tyrone_40 View Post
    @Baleno1300, I would like to try this on my Belta with 43k kms on it. Have you used it too? Just one query, when you put in the ceratec (300 ml) do you reduce the engine oil qty by 300 ml or you put in the full 3.1 litres which is recommended for my car?
    Yes you can use the same MoS2 oil in your Belta also. It will be very suitable.
    With MoS2 Engine Oil or Additive, do not use the Cera Tec as there would be too much solids then with the oil. Use Cera Tec or MoS2 separately as they both have same sort of function.
  3. #242
    tyrone_40's Avatar
    Jan 2005
    Other
    1,230
    2 Post(s)
    Quote Originally Posted by zank View Post
    Great!! Thanks for the reply. I use Shell UltraHelix fully synthetic and will use the ceratec at my next oil change.
  4. #243
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    If you can afford then do try the LM SynthOil fully synthetic engine oil and mix Cera Tec with that. This is a very good oil with long oil drain interval. Last time I changed at 10K kms in my car, and still then I didn't feel that my oil is lagging any properties.
  5. #244
    fahadwizz's Avatar
    Feb 2011
    31
    1,537
    18 Post(s)
    Changed my oil to Mos2 10w40 today from plaza motors defence. Got 4L pack for 3300/- and some "good quality filter" for 250 as per the shop guy's recommendation. He said this filter will good for 10k and oil can last as long as 20k kms. I don't think i can wait even half of these kilometers but lets see.
    I am still to witness the impact of this as right now i don't feel much difference. But then i have only driven 15km since the change. I have heard this take a couple of day's driving to actually start working.
  6. #245
    asmile79's Avatar
    Sep 2006
    33
    348
    I am also planning to use Liqui Moly 10W40 MoS2 for my corolla fielder 2006.
    Previously i was using 15W-40.
  7. #246
    snake1's Avatar
    Apr 2012
    salam brothers,
    i just have a simple question that if some one has zero meter corolla gli 1.6 2012, after how much mileage he should use ceratec ?
  8. #247
    margallar's Avatar
    Oct 2009
    17
    6,144
    5 Post(s)
    i think you can pour it in at the second oil change
    the paint whisperer
  9. #248
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    Quote Originally Posted by snake1 View Post
    salam brothers,
    Use it after 3K kms.
    It will give the best possible protection for new cars.
    Sent from my HTC Desire using Tapatalk 2
  10. #249
    123321123's Avatar
    Jun 2008
    82
    2 Post(s)
    i have a question. please guide me
    i have corolla GLi, 185ooo odo. no oil reduction but i feel roughness in engine plus noise. i am using toyota 20-50 engine oil
    Gear is also getting abit harder to shift in 1st and 2nd gear.
    i want to use Liqui Moly products. suggest me following
    1- Engine Oil (guide also if changing grade can b a problem or not)
    2- Ceratec should be used or not in engine
    3- Gear additive.
    Help would be highly appreciated
  11. #250
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    Quote Originally Posted by 123321123 View Post
    3- Gear additive.
    1. As you have relatively an older engine, therefore you should use Liqui Moly LeitchLauf MoS2 10W40 Engine Oil. Use it with genuine oil filters and you car can easily do 8K kms.
    2. This oil already has MoS2 particles blended by the company, so no use for adding CeraTec.
    3. For Gears use, LM MoS2 Gear Oil additive, this is a highly recommended product. It comes in a tube and gets added to your existing gear oil if its still usable and you are not changing.
    123321123 likes this.
  12. #251
    hamz80's Avatar
    Oct 2008
    32
    233
    I know this question has been asked before but i have not been able to find a reliable outlet for Liqui Moly Products, here in Lahore?
    Can anyone of you help me in this context?
  13. #252
    123321123's Avatar
    Jun 2008
    82
    2 Post(s)
    Thanks @ zank.
  14. #253
    fahadwizz's Avatar
    Feb 2011
    31
    1,537
    18 Post(s)
    After driving for a few days here are the things i have noticed.
    - Better cold start
    - Engine feels smoother and lighter (less drag)
    - improvement in mileage
    Using 10w40 mos2 lietchauf
    amm likes this.
  15. #254
    amm
    amm is offline
    amm's Avatar
    Oct 2005
    25
    207
    Quote Originally Posted by fahadwizz View Post
    - Better cold start
    dude from where i can buy Liqui Moly Ceratec in KHI ? and where this Plaza Motors Defence situated ( how was their service ) & does they have genuine products of LM ?
    High revs for nothing ! without turbo purge
  16. #255
    fahadwizz's Avatar
    Feb 2011
    31
    1,537
    18 Post(s)
    Quote Originally Posted by amm View Post
    While driving on khayaban e ittehad , take left just before korangi road signal on double nala wali road. Take right into the lane from first u turn. U wiil b on 12th commercial lane and the shop will b on the right side. U will find many honda authorized dealers in this lane. Oil is genuine n he doesnt have oil change service.
    Sent from my iPhone using Tapatalk
  17. #256
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    And if you take the reference of PW and me, you will get a discount also :-)
  18. #257
    zank's Avatar
    Feb 2009
    33
    1,318
    5 Post(s)
    - Better cold start
    Yes these are common observations after switching to LM. Which oil were you using before by the way?
  19. #258
    fahadwizz's Avatar
    Feb 2011
    31
    1,537
    18 Post(s)
    I availed that discount
  20. #259
    MUNZALEEN's Avatar
    Mar 2011
    Multan
    206
    Assalmoalaikum
    Is liqui moly products available in multan.
    If yes then location?
    or not then how can i get it thanx.
  21. #260
    fahadwizz's Avatar
    Feb 2011
    31
    1,537
    18 Post(s)
    I was using fuchs. Changed it at 3k. Its also a good oil but LM is by far the best thing u can do for your engine specially the ones with high mileage where a lighter synthetic is not suitable.
Similar Threads
  1. where to buy liqui moly oil from ?
    By NaXuN in forum Member Opinions & Suggestions
    Last Post: 21-11-2012, 10:28 AM
  2. Liqui moly oil
    By mostwanted_legend in forum Oil / Fuel / Fluids / Filters
    Last Post: 14-12-2010, 12:26 PM
  3. From Where to get Liqui Moly in khi ?
    By 7650 in forum Oil / Fuel / Fluids / Filters
    Last Post: 05-11-2010, 06:17 PM
  4. Liqui Moly
    By aahmedt in forum Oil / Fuel / Fluids / Filters
    Last Post: 21-10-2009, 05:18 PM
  5. Liqui Moly Oil. Where to get it from?
    By whiteangel in forum Miscellaneous Items
    Last Post: 07-10-2007, 02:52 PM
