car was serviced 2 days ago, asked them to clean the engine properly so i can see the leakage
today morning i rubbed my hand below the pump but it was all dry, n there was no oil on alternator as well, if thats the thing right below it.
generator belt felt kind of wet, the area that was visible from above but rest all the things including the pipe were dry, the one that mechanic said is leaking from the joint behind air filter
Dont know what is causing the leak, as the porch area where car is parked is showing oil marks like if it had spilled there at night time, noticed that 2 days ago, though nothing after that n no such thing at the parking space where it is parked all day
seems like maybe either something causes the leak n then it stops or now its leaking very slowly
how can i be sure if pump needs to b changed or not as its all dry, maybe the seals did worked, n maybe even after changing it oil may keep leaking from else where
