Please check your placement on the map - I beleive its Pakistan. there are no safety or emmissions mandates in that country - meaning there is no one to check exhaust emmissions or even vehicular safety.
the reason to remove such high pressure additives was to save the cat converter from dying early, As it created another host of problems, most (sensible) manufacturers employed different technologies to remove the high pressure areas in their engines (roller cams, bucket/shim/hydraulic/solid tappets etc) - Pakistan has no mandate to have a cat converter - infact this very forum has a ton of threads of people advising to remove the cat because it affects "parfarminss" of their econocar.
your beloved cultus efi has the same old ancient "buzurg" G series suzi 4 cyl engine that we have been seeing since we were roaming around in shorts, it still uses a soft cam and silly rockers with a pretty silly breathing setup aka, choked design - meaning rev more.
Be assured that ancient API - SC, SE, SG, SH, SL - CH4, CI and CJ oils are not going anywhere from shelves in Pakistan, the insane numbers of Honda CD70E and CG125E and ancient mazda and bedford diesel engines in Pakistan will fail catastrophically in short time. Your cars are the drop in the bucket (those motorcycles and the trucks are entire water the bucket) - please add the first paragraph to this mix and you will know why it would be "a huge loss" to remove such oils from the shelves.
