If you want a Prado, Land Cruiser, Lexus, Corolla, Honda, Mercedes or any other second hand car, I can get you a good deal at rates lower than the market. The car shall be delivered at your doorstep WITHIN fourty five days. If you're interested, call or reply now. You may contact me here in Islamabad at 0321-5016157 or via email at mvrs102@hotmail.com . Following is an ad of an Ist readily available right now. It's Black in color, Automatic and gives an average of 16km/ltr. I am trying to attach the pictures but am unable to do so at the moment. Shall be here soon Inshallah.
Toyota ist 2002
Modification 1.3f, produced from 2002 (may)
Terms and abbreviations
Add to comparsion list
GENERAL
Body type Hatch
Drive FF
Transmission Super intelligent 4 speed automatic (Super ECT)
Displacement, cc 1298
Frame UA-NCP60-HHPNK
Price of new car, thousands yen (Tokyo area) 1250 (~$10400)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 3855 x 1695 x 1530
Interior dimensions (LxWxH), mm 1805 x 1395 x 1260
Wheel base, mm 2370
Treads (F/R), mm 1455 / 1435
Ground clearance, mm 175
Curb vehicle weight, kg 1000
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.3
Fuel tank capacity, l 45
ENGINE
Engine model 2NZ-FE
Max.power (Net), kw(PS)/rpm 87 ps (63.99 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.3 kg*m (120.62 N*m) / 4400 rpm
Power density 11.49
Engine type Serial 4 cylinder DOHC
Engine information VVT-i
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 10.5
Bore, mm 75
Stroke, mm 73.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.5
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 185/65r15 88s
Tires size rear 185/65r15 88s
Braking system, front Ventilated disk
Braking system, rear Drum (leading/trailing)
Suspension system, front Strut type coil spring (stabilizer attaching)
Suspension system, rear The torsion beam type coil spring (stabilizer attaching)
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof
Front fog lamp
Rear fog lamp
Xenon headlight (Discharge lamp)
Projector headlight
Rear wiper
Front spoiler
Rear or roof spoiler
ABS (Antilock brake system)
TCS (Traction control system)
LSD (Limited slip differential)
Privacy glass
UV cutting glass
Aluminium wheel
INTERIOR EQUIPMENT
Air conditioner Manual
Wood panel
Cruise control
Centralized door lock
Power window
Steering wheel telescopic
Steering wheel tilt
Leather steering wheel
Power front seat
Power rear seat
Leather seat
Falling down type rear seat Divided type
Child seat fixed with seat belt
Rear ELR3 point seat belt
Front seat pretensioner seat belt
Fourth limited front seat belt
Side impact bar
Airbag (Driver)
Airbag (Passenger)
Airbag (Side)
Audio deck AM/FM radio equipped MD player
CD-player Single equipment
Car navigation system
- present - not present - option
Colors
Color spectrum Color
Black mica
White
Dark blue mica metallic
Silver metallic
Super red V
Blue metallic
Beige metallic
Option
White pearl mica
Transmission (AT / MT / CVT) 4AT / -- / --
Price, yen (AT / MT / CVT) 1,180,000 / -- / --
Length / Width / Height (mm) 3855 x 1695 x 1530
Wheel base (mm) 2370
Track, front/rear (mm) N/A
Clearance (mm) 175
Turning radius (m) 5.3
Weight AT / MT / CVT (kg) 1000 / -- / --
Doors 5
Seating capacity 5
Interior Length / Width / Height (mm) 1805 x 1395 x 1260
Colors White
Red
Dark blue
Brown
Black
Blue
Pearl
Silver
Engine 2NZ-FE
Engine type inline 4-cylinder DOHC - VVT-i
Turbo (Super) charger / VVT none / VVT
Bore / stroke (mm) N/A
Engine displacement (cc) 1298
Compression ratio N/A
Maximum power AT / MT / CVT (ps/rpm) 87/6000 / --/-- / --/--
Maximum torque AT / MT / CVT (kg-m/rpm) 12.3/4400 / --/-- / --/--
Ecology equipment Ultra-Low emission vehicle (U-LEV)
Layout (Engine / Drive) Front / Front
Final drive ratio N/A
Front suspension Strut system with coil springs
Rear suspension Torsion beams with coil springs
Front brakes Ventilated disk
Rear brakes Drum, Leading trailing type
Tire size 185/65R15 88S
Fuel type Regular gasoline
Fuel tank capacity (liter) 45.0
City mode economy AT / MT / CVT (km/l) 18.0 / -- / --
60km/h economy AT / MT / CVT (km/l ) -- / -- / --
Standard Equipment
Driver's seat airbag
Passenger's seat airbag
ABS
Brake assist
Safe powered windows
Door side bar
Air conditioner
Powered windows
Powered steering
Tachometer
Central door locks
Right steering wheel
Tilting steering wheel
Divided falling seats
Powered mirrors
Anti UV windows
Front stabilizer
Rear stabilizer
Optional equipment
Side airbag
TV
Fog lights
Rear fog lights
