Thanks testdriver for kind response. I have genuine AC compressor installed,yes radiator fan woks in auto mode. No additional condenser fan is installed. G8 Tahir has changed IAC valve to rectify the issue, then on follow on visit his student hit the compressor clutch to squeeze the clutch gap ,and then on next follow on visit his electrician installed the relay in compressor clutch coil circuit to enhance current supply to clutch coil,but problem persist.
The other issue is high RPM issue. The RPM remains high till engine heats up or even later and some time goes high on heated engine. Kindly give your expert opinion.
