@testdriver or anyone
Thanks sir. I also have a question to ask from you.
I'm having a problem with my dohc woo. The problem is that it sometimes misfire on petrol. If i accelerate slowly it dont misfire but if suddenly throttle is given then it misfires. I've change the fuel pump to bosch pump that's for honda civic vti 1997 and changed the fuel filter under the rear door foot panel. It's still misfires very rarely but now has good pick. It was misfiring heavily as the fuel level was low and i gave it a rs. 500 petrol. It got better but misfired one time after a hard run. It is to be noted that i've installed an aftermarket air intake. Also I checked the plug wires which are giving 5.38 - 5.8k ohm resistances. What shall be the optimum resistance? I'm going for 10.2mm aftermarket plug wires (and the connectors have to be changed) on sunday. Car is also having cng. But on cng it dont misfire. Unless I put the car third gear around 20-30kmph and press throttle and thats obviously my mistake and that too after installing CAI.
Now i'm planning to supercharge it (around 2~4 psi) and in that case a misfire could be a havoc for the engine. Shall I go for injector cleaning or something else? What shall be done please guide. Also if you could tell me of any good shop for getting aftermarket plugwires
Also if u remeber my elder brother (taimoor khan) has contacted you an year ago when we were in process of swapping the engine.
Sorry for such a long post but I'm sure u'll help me resolving the issue.
Regards.
