@Welcome786
Did you get it scanned? If not, better get it done. I think either fuel pump or the injector has some problem.
@Javaid35
Top portion of shocks :(....I think you are confusing the complete shock assembly with shocks. Actually the dead shock is brought out of the assembly and then new one is replaced in. I am not sure about Sangin, but if the parts dealer is trustworthy, you can go for it. Kabli are still not advisable.
@Daemon
In winters, due to hard engine cranking in the morning, more battery power is required as well as more fuel. So, it is advisable to avoid engine tune-ups during winters. For a better startup on CNG I have a working formula:
Boil around 1 Litre of water and then pour it on the CNG regulator before starting in the morning. You will get better startup on CNG in winters. (y)
