Test Driver
I need your help on following issues
(a) Want to install radio antenna. Which antenna is good and kindly tell me its location. My cielo is not installed with antenna.
(b) Engine produces knocking sound. Previously installed CNG kit was removed and there is no hole in the air intake pipe. Kindly tell me how to reduce it. The pick up reduces while accelearting and engine knocks. Technicain told me timing is advanced. Kindly tell me how to fix it.
(c) On start up the engine is very quite (no noise with open bonnet except tick tick i suspect tapet noise) but it can be heard inside the car. The boot installed on the steering rod is missing and not available here.
(d) Chinese Brand new AC Compressor (507) costs about Rs 5500/- while kabli ceilo costs about 1800/-. Which one should I prefer?
(e) While driving ECU lights comes on especially while accelerating after applying brakes and engine knocks. After restart it goes off. Uniform speed does not gove problem but acceleration after decelaration gives problem.
(f) I bought engine sheet (to avoid engine from road dust) for Rs 1200/- from Lahore. Its in two pieces and dont know how to install it.
(g) There is play in the gear lever. I installed new lever kit it improved but not eliminated. How can it be eliminated?
Thanks in advance.
Assad Abbas
